need my bottom end rebuilded on ls
i need it done can anyone do it and for how much i have a rod knocking and need it fixed asap i can get all the parts at holesale. also how hard and what tools do i need to do it myself. i know the basic of a rebuild but not sure about it all. so if some one can help me out please thanks
Aim: Hondacrxls
Aim: Hondacrxls
Originally posted by sl0 t3g
get a factory honda service manual, it tells you how to do an overhaul and what needs to be done.
Aim: Hondacrxls
Aim: Hondacrxls
It is called a helms manual
helmsinc.com
helmsinc.com
if you just have a rod knock get some new bearings and buy mtber's LS crank, swap bearings and crank and you should be good to go. you can get a chiltons or haynes from your library. it will have all the info you will need.
