need my bottom end rebuilded on ls
Old Jul 6, 2004 | 09:29 PM
  #21 (permalink)
IdrvaAltima's Avatar
Teamtuffguy
Originally posted by Vito_Corleone
"RebuildED" huh?
You're one step ahead of me.
If it aint Greasy i don't want it.
Old Jul 6, 2004 | 09:53 PM
  #22 (permalink)
InsaneCivicCoupe's Avatar
Retired Ricer...
The head will have to be pulled reguardless, as the block will need a fresh hone... I say go ahead and buy some new pistons, like some b16 pistons with rings, hone the block to make sure the cylinder walls are nice and smooth and wont eat up the new rings, buy the crank from mtber, get the proper bearings (they go by color code based on the mic) and while you are at it, it wouldnt hurt to replace the oil and water pumps with some off of a vtec motor.... after all this, throw it back together with new bearings and gaskets where needed (you can buy rebuild kits that will include all of this) put some easy-goin grandma miles on it to make sure everything seats right, and be sure to change the oil after the first 30 minutes, then again after 200 miles, and again after an additional 500, then just keep it changed as often as you can afford... it is reccomended at LEAST every 3k, but I change mine about every 1500 just to be safe... Good luck with it and I hope all works out ok....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jul 18, 2004 | 04:21 AM
  #23 (permalink)
HondaCRX's Avatar
Vtec what?
i need a new rod for my ls the spun bearing fu*ked it up. could i use a b20 rod or do i have to use a b18 rod lmk thanks
Aim: Hondacrxls
Old Jul 18, 2004 | 06:18 AM
  #24 (permalink)
qitstrn's Avatar
Can you spot me 20 cars?
You need an LS rod. Is the crank still ok? you might want to check it.
Old Jul 18, 2004 | 06:38 AM
  #25 (permalink)
HondaCRX's Avatar
Vtec what?
got a new crank up did not think the rod was bad so now i really need one asap. if any one has one send me a pm thanks
Aim: Hondacrxls
