need my bottom end rebuilded on ls
talk to Crix he will do it for a good price..ffor a Ls it is fairly easy you dont even have to take off the head BUT I WOULD CHANGE OUT your pistonss rings also to insure longer life of thaat motor
i love AUTOZONE
i love AUTOZONE
Originally posted by juiced2ndgenteg
if you just have a rod knock get some new bearings and buy mtber's LS crank, swap bearings and crank and you should be good to go. you can get a chiltons or haynes from your library. it will have all the info you will need.
Aim: Hondacrxls
Aim: Hondacrxls
ok just drained my oil and there is no metal shavings ( i thought there would be) does that mean that it was not a spun bearing??? or is it just the wear now the old bearings
Aim: Hondacrxls
Aim: Hondacrxls
could just mean wear out bearings or maybe its stuck in the pick up.maybe your thrust wash is wear could be couple of things
i love AUTOZONE
i love AUTOZONE
