D16y8 ....
Old May 18, 2004 | 04:21 PM
keyelements92's Avatar
Default D16y8 ....
iv got a 92 cx ... iv descided to keep with sohc. i just blew the stock cx engine wich is supa slow.. so im puttn a D16Y8 and then im gonna turbo it.. well wen i do the swap.. besides the ecu.. wut all am i going to need............
and does anyone kno were i can get one!
Old May 18, 2004 | 05:47 PM
NitrousAcid069's Avatar
4.6L Rice Eater
i would recomend getting a d16z6 motor, the head flows better and it is obd1....obd1 is a lot easier to tune....next thing....if you are serious about turbo charging it...i would recommend throwing a dx head on the z6 block. you will then have a low compression motor...and also, you then wont have to worry about wiring VTEC in the harness and changing the ECU. when you thin about it....losing vtec is only losing 19hp which could be made up for in leaps and bounds with boost....
John
Old May 18, 2004 | 05:56 PM
MacGruber's Avatar
MaDe Of MoNeY
I just thought sence you wanted to get a b16 Vtec but couldnt afford it so thats why I suggested SOHC Vtec. low compression is the way to go. all very good points. didnt some one do that on here with a ef? also you could always get hondata or uberdata along with the turbo set up.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old May 18, 2004 | 08:40 PM
crix's Avatar
:mugen member:
the d16y8 will work fine.
you will need to use your trans/axles/motormounts,enginewire harness,distributor,obd1 injecters,the intakmani/cylinderhead has biggerports better flow & a B16 throttle body bolts up to intake mani..which increases hp..been there done that...
