Ls All Motor Question
Old Apr 21, 2004 | 07:00 AM
  #21 (permalink)
TRD_Tc's Avatar
Using The Force Of N/A
I'd want to use the B16A P30 pistons right?
Old Apr 21, 2004 | 08:56 AM
  #22 (permalink)
mtber's Avatar
Sure, but for the 100000th time on this forum.
You can't just slap pistons in to a motor.
You should replace all:
Bearings, Pumps, Seals, Gaskets etc..
You also have to pay a machineshop to open each p30 piston 1mm on each side to accept your ls rods. They then press the wrist pin on & hone your cylinder walls etc..
Old Apr 21, 2004 | 05:51 PM
  #23 (permalink)
RONIN's Avatar
Tetris on a stick
Yeah I was reading up on the pistons a little....which ones should I use? They say certain ones wont work with the Crower Cams.
honda motors are interference motors, the concern is that with too much lift the valve could contact the piston... but you would need your cams to be adjusted pretty far for that to happen.
feel free to pm me for questions on the ls, esp with crower cams.
but as was said before, don't expect too much from boltons on a ls stock. i wouldn't even refer to i/h/e, cam gears, as being 'all motor' just bolt-ons.
