Ls All Motor Question
Old Apr 20, 2004 | 06:25 PM
TRD_Tc's Avatar
Using The Force Of N/A
ok, then tell me what else I could do so it will have a point
Old Apr 20, 2004 | 07:08 PM
mtber's Avatar
Crane 0012 cams or crower stage 2 cams
Shaving your head 20-30 thousands (ls heads are cheap as hell)
2 ply OEM headgasket
Cam gears
safc for tuning
Old Apr 20, 2004 | 07:16 PM
TRD_Tc's Avatar
Cam gears
safc for tuning
What's that going to do for my Track Time? As well as my daily driving?
Old Apr 20, 2004 | 07:17 PM
TRD_Tc's Avatar
Cam gears
safc for tuning
What will that do to my track time as well as my Daily Driving?
Old Apr 20, 2004 | 07:20 PM
mtber's Avatar
It depends how serious you get...
For example.. When I installed crane 0012 cams into my old car, my e/ts went from 16.0s an 15.9s to 15.5s UNTUNED with everything at TOP DEAD CENTER.
If you milled your head, installed cams, used camgears, a fuel controller such as an safc, dyno time You would see pretty decent improvments for the money invested.
Cams - $400
Cam Gears- $200-300
Safc - $250
Head milling - $25 plus a headgasket & head studs $200 total
Tuning - $200-300
The only good thing about this aproach is you can do it little by little.
If you truely want to make power, purchase a turbo kit, but its a big investment....
Old Apr 20, 2004 | 09:28 PM
integrakev78's Avatar
(Torqueless Wonder)
Spend a little bit of money and get a zex 75 shot
Old Apr 20, 2004 | 09:44 PM
  #17 (permalink)
mtber's Avatar
He said ALL MOTOR
Old Apr 21, 2004 | 06:43 AM
  #18 (permalink)
TRD_Tc's Avatar
Well the Zex Kit might be down the road....but I want to stay all motor for as long as possible. Thanks for the Info mtber .
Old Apr 21, 2004 | 06:52 AM
  #19 (permalink)
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
ok i went 14. with my ls. i had, intake headers and itr pistons. my car was also 2262lbs stock. i dont see you having a problem running mid to low 14's with a fully built ls. your never gonna get anywhere with oem pistons in there so thats a definate upgrade. as far as the intake manifold??????? i wasnt to sure about getting one because ive never seen anyone use a after market manifold on a ls and i would want to see in person how it performed. but swapping a vtec head would be better off
tamparacing.com
Old Apr 21, 2004 | 06:57 AM
  #20 (permalink)
TRD_Tc's Avatar
Yeah I was reading up on the pistons a little....which ones should I use? They say certain ones wont work with the Crower Cams.
