problem wit swap
I have a 96 civic hatch and i swapped a sir2 b16 into it. I wired everything and timed it. I also have no codes. My engine idles fine but when u try to rev it it just dies out at like 3500. It wont go pass 5000 rpms at all. Does anyone know what my problem is cuz it would really help me out.
thanks
thanks
Originally posted by crix
yes it will IF u jump the wires from the plug
IF U need help LMK..........
i can repair if your in tampa area
call or lmn........
call or lmn........
what do u mean if i jumped the wires from the plug?
The plug is on the bottom right side of you glove box you have to reach up and pull it down should be in a litle rubber holder thing but I wouldnt recommend doing it unless you know which plug is the right one.
www.artofspeedproductions.com
