dyno'd junkyard setup
cronic, i use my egt gauge to roughly tune fuel.
if im running too too lean, my egt's will climb like a mofo
Originally posted by Cronic
I'm still not sure how an EGT can show you how to tune timing...
If the timing is not sufficient, it will become obvious when EGTs go up as fuel is added. I have seen this first hand with my Dodge. Its pretty spooky when you add 75-100 hp worth of alcohol and the EGTs go up 150 degrees with the exact same advance and no knock retard! But, it confirms where the problem is conclusively. All that extra fuel is burning too "late".
Larry
2002 MB C320 Sport Wagon 15.4@91
2002 Dodge Neon SE
1991 Dodge Spirit R/T-12.3@117 (at 368 whp) Now 500 whp / 514 ft lb on pump gas
Larry
2002 Dodge Neon SE
Also, that's very good power for a t3. Matter of fact, it's crazy power with a t3.
Turbo was a T3 55 trim (teeny tiny bit larger than the more ubiquitous T3 50 trim) in a 0.42 A/R comp housing paired to a standard T3 turbine in a 0.48 housing.
Larry
2002 Dodge Neon SE
Larry
2002 Dodge Neon SE
Guest
Posts: n/a
Originally posted by VeRTigO
cronic, you must be shittin your pants when u see people running 20lbs of boost on 14b's on 16g's and stuff. I am more than happy with the power I am making. I can beat 99% of the cars on the street and have a nice powerband
No I don't shit my pants, because 14b's are still efficient at 20psi (actually that's about where they stop being efficient, and you dont run more then 20 on a 14b)
Guest
Posts: n/a
An egt is not a safe way to tune, I realize a narrowband will _roughly_ show you that you are rich or lean, but it's NOT a great way to tune. Neither is using egt's to tune timing. From my understanding it's much more accurate on a dyno. Since he was ON a dyno with a wideband... I was curious why he did things the hardway.
Lots of replies are going here...
