Brainiacs Only....
Old Feb 13, 2004 | 12:52 PM
01IntegraGSR's Avatar
...transformer...
Default Brainiacs Only....
Well the fuel pump is not priming and I'm getting no spark at the distributor. I have replaced both, checked the fuses, and checked the timing belt. It is not the alternator in case you were going to suggest that as well. So, I guess I am left with either the relay or ECU. I am at a loss. What do you all think could be the issue? If it is the relay or ecu, could someone let me borrow theirs to try as a solution? Then I'll be able to go out and get one sp my car will run. Thanks in advance for any advice/solutions given.
Old Feb 13, 2004 | 01:03 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
What kind of car?
Old Feb 13, 2004 | 01:40 PM
...transformer...
Awesome Keith! Thanks...I'll be calling you
Old Feb 13, 2004 | 03:06 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
I have a P06 which is the proper ecu if you wanna try it.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Feb 13, 2004 | 03:45 PM
...transformer...
Thankyou Chris...Ill get in touch with you
Old Feb 13, 2004 | 04:03 PM
60-1EK's Avatar
Engineer at the source
check the starter signal fuse under the dash. Happens all the time.
JAson
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 14, 2004 | 02:14 AM
Old Renegade's Avatar
Cool Runnings
MAIN RELAY it triggers everthing it clicks if its ok and not stuck the fuel pump will prime and when its done main relay will click.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Feb 15, 2004 | 12:08 AM
...transformer...
Question
Well I have located the main relay. Is there an easier way to get to it besides taking out the entire dash? My hand is small, but not small enough to fit into the area to touch it. If anyone has replaced the Main Relay in 92-95 hatch before, can you please inform me of the best way to get to it? Thanx.
