good sparkplug for n2o?
Originally posted by 02CavyZ24
35-50 wet
35-50 wet
Oh you will be safe with stock plugs. I have sprayed 120 shots on a all stock D16A6 all day on the street with stock plugs. It worked good. Just make sure you ignition system is in tip-top shape. If you r doubting it just upgrade. You will be fine.
Guest
Posts: n/a
guy is right....The higher the 2nd to last # is the colder it is so for example if BKR5E was stock then BKR6E would be one step colder.
14.7 psi all day and night, like its my job.
