ls/vtec with nitrous?
i havent really chosen if i want to do ls/vtec or gsr. but i just have a question about the ls/vtec.. once i get it and put it in i was thinking about putting nitrous for the extra boost while i save for a good turbo set up.. would this be a good idea to do on a ls/vtec?? if so is there anything on the engine i should replace before doing so?? thanks.
[url]
69 Buick Skylark - Brokeded
91 CRX hf (zc dohc swapped) - wrecked/fixed-wrecked/fixed-wrecked-sold
91 Civic hatch (stock) - Sold
91 CRX hf (ls swapped) - Traded
90 Civic Hatch (mini me) - Sold
91 CRX si (zc dohc swapped) - Brokeded
02 Dodge Ram - gave to repo man
06 gsxr 600 - Wrecked
95 cbr f3 (stunta) - Sold
96 Integra ls - Sold
94 Integra ls - Sold
02 Dodge Ram - Daily
[url]69 Buick Skylark - Brokeded
if it is built right you shouldnt have any problems as long as you go with a wet kit
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
i dont know much about nitrous.. but what is the true difference of a wet kit or a dry kit?? someone pease inform me!?!
[url]
in my opinion, and knowing alittle about it, personally i would go LS/turbo, or GSR/turbo. i know if you build a LS/V-tec right it will be reliable but the R/S ratio of LS/V-tec sucks and adding to the stress on it with NX , doubles your chances of throwing something.
i would just boost a gsr, or a LS. that way it would be less prone
to killing it.
not tryin to put you down, but it would save you alot of money and be more stable in the long run.
to killing it.
ls turbo w/ factory internals at 7 psi will make about the same power as a well built ls/vtec for about the same amount of money.
what you need to ask your self is what are your goals ?
how much risk factory do you want ?
is this your daily driver ?
The list goes on.
Just use common sence.
The list goes on.
how much hp do you think i can get out of the ls/vtec built and turboed??
[url]
wow not what im looking for.. i think i might go with the gsr here.
[url]
welli am looking for 400hp.. so i am guessing that the additional 30 hp will help me out..
[url]
