Precision SC50, what A/R?
I am considering a Precision SC50 for my D16Y8 and trying to figure what A/R would be best. Some tell me that the .48 would be best because I will not be increasing redline since the head is stock, so it won't choke up top but still spool really fast. Others have said that the .63 will make more power and more lag for a FWD street car means more traction. I'd like to hear some more opinions. Goals are 250-300whp on pump gas. Maybe more on race gas some day.
Setup will be:
SRP pistons and rings
Eagle rods and ARP bolts
GE block guard
ARP head studs
Precision intercooler
Tial BOV and 38mm waste gate
Mav Rev manifold and downpipe (want to keep A/C)
RC 550cc injectors
Hondata S200
Thanks,
Ryan
Setup will be:
GE block guard
ARP head studs
RC 550cc injectors
Hondata S200
Thanks,
Ryan
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Also fogot to mention, I'm trying to decide whether I can stay with what SRP claims to be 10.5:1 C/R but actually calculates out to be more like 10.1:1 C/R or if I need to lower it with a thicker headgasket. Setup was originally running nitrous which is why I started out with more compression.
Thanks for the info, I think I'll go with the 10.1:1 C/R and the .48 A/R.
I just found out that the Lovefab SST manis can fit on a SOHC with A/C if you use the 2.5" downpipe. I was thinking that would be a better option that the Max-Rev.
Also, wouldn't I need an electronic boost controller to reach boost levels that meet my power goals without spiking?
Guest
Posts: n/a
[QU073][1]0|21g1|\|4lly p0573d by |2y4|\|C1v1c2000 [/1]
1 ju57 f0u|\|d 0u7 7h47 7h3 L0v3f4b 557 m4|\|15 c4|\| f17 0|\| 4 50HC \^/17h 4/C 1f y0u u53 7h3 2.5" d0\^/|\|p1p3. 1 \^/45 7h1|\|k1|\|g 7h47 \^/0uld b3 4 b3773|2 0p710|\| 7h47 7h3 M4><-|23v.[/qu073]
Much b3773|2 0p710|\|! 17'll 5p00l 4 l177l3 b3773|2 45 \^/3ll.
[qu073] 4l50, \^/0uld|\|'7 1 |\|33d 4|\| 3l3c7|20|\|1c b0057 c0|\|7|20ll3|2 70 |234ch b0057 l3v3l5 7h47 m337 my p0\^/3|2 g04l5 \^/17h0u7 5p1k1|\|g? [/QU073]
|\|33d? |\|0. 7u|2b0><5 m4k35 4 |\|1c3 m4|\|u4l b0057 c0|\|7|20ll3|2 \^/h1ch \^/1ll 5u17 y0u f1|\|3. \^/4|\|7? \^/3ll, 0|\|ly y0u c4|\| 4|\|5\^/3|2 7h47...
What type of boost controller would you recommend? I am on a budget though, nothing too fancy.
