Conn. Rod Strength
Originally posted by ItsSoDookie
if you plan on staying around the 300hp mark, stock rods are fine, get them shotpeened/polished and balanced if you are on a budget and cant afford forged ones
the pistons is what you have to worry about, i think its weakest point on the bottom end of our engines
Pmed
i love AUTOZONE
i love AUTOZONE
Originally posted by Vapor
it's cylinder pressure spikes (aka detonation) that blows the ring lands of the pistons out, not heat.
is it that big of a fctor in low pressure setups ? everything ive ever read is that heat at that high of a cr kills piston strength ? i never thought of the rings coming apart, only under high psi have i ever seen that ? See thats hwy your da man.
