vtec bogs down bad..
Old Dec 26, 2003 | 05:00 PM
civicracer901's Avatar
B16ACRX
Default vtec bogs down bad..
I hit like around 4400 rpms and kicks back really hard. I checked both filters there clean. You think its fuel related or maybe not geting enough oil pressure? I have a oil pressure gauge but I have no idea how to hook it up. I know where it goes. I dont know.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Dec 26, 2003 | 05:34 PM
B16ACRX
top
Old Dec 26, 2003 | 06:44 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Have you checked your oil? Is it full? Are you throwing any codes? If your oil is full i would say fuel, don't have much experience with this, so if i'm wrong someone let me know.
Old Dec 26, 2003 | 09:13 PM
Punkinterviews's Avatar
Chavez Motorsports
Add vtec fluid
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Dec 26, 2003 | 09:44 PM
2qk4u's Avatar
does it stop bogging or keep doin it.
u prob need more gas if ur vtec setting is that low
i would just stick with 5300
Old Dec 27, 2003 | 07:49 AM
WHOA! Your Vtec is set to engage at 4400, or that's when it bogs? If you set it that low (without a dyno) you're a moron and i would say that is your problem.
Old Dec 27, 2003 | 04:54 PM
B16ACRX
jason: its fine sometimes and rides good and strong but then somtimes it bogs down at that point like its not geting enough gas.
Old Dec 27, 2003 | 05:14 PM
B16ACRX
4400 works great it almost feels like a misfire though like it runs on 3cyls when this happens. I know when iam driving the car at when it bogs down once a code flashes which would be code 73
7 lengthy flashes follwed by 3 quick flashes. But isnt this a obd0 car? Its a pr3
Old Dec 27, 2003 | 08:29 PM
Jdm Civic's Avatar
It could be your o2 sensor. My friend had this same problem happen, and he had a bad o2. Not sure, but check it out.
Old Dec 28, 2003 | 01:45 PM
B16ACRX
ok will do that thanks. What NGK plugs do I use is there a certin kind?
