vtec bogs down bad..
Old Dec 28, 2003 | 07:25 PM
chinogsr1's Avatar
Originally posted by Vito_Corleone
WHOA! Your Vtec is set to engage at 4400, or that's when it bogs? If you set it that low (without a dyno) you're a moron and i would say that is your problem.
what wrong wit set vtec at 4400rpm,
Old Dec 29, 2003 | 01:58 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Lowering Vtec is, in most cases, bad for power. If you have it dyno tuned and they set it low that's different.
Old Dec 29, 2003 | 04:17 AM
KJ's Avatar
KJ
bored at work
4400 is stock for a gsr and that is also where the mugeb pr3 program puts it. Not saying that is very good but on stock b16a1 cams it isn' that bad. A code 73 on a pr3 ecu would tend to lead me to believe the ecu is fucking up since that code does not exist in obd0. The same thing happened to me a long time ago when a chipped pr3 started to go bad. Try a stock ecu or just a different one.
Old Dec 29, 2003 | 05:15 AM
civicracer901's Avatar
B16ACRX
I pulled out my plugs since it was saying I had a misfire and I think on obd1 73 is a misfire, not sure what cylinder but I pulled them all and find out that the plugs are hot also cylinder one(one closest to the timing belt side) has a oil on it. All other 3's where just hot which is cause the heat range on the cheap plugs that I had no idea would make that much of a differnce.
I will go buy some NGK's today and find out if thats my problem. Are there certin kinds of NGK plugs to buy like standard and platnuim kind, or I think they have a split one.
The motor only has like 40K-50K I doubt its the rings,vavle guides. or seals.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
