results from lowering vtec engagement??
lowering helps you in NO way what so ever as above stated its set that way from the factory for a reason,none of your friends are smarter then honda's engineers,an no from my experince it doesnt depend on what cams you have, name one worth a shit after market cam that makes better power then stock cams on a vtec motor with a lower vtec crossover then a type R ?
97 ITR-Mugen Equiped
04 Honda 600RR
04 Honda 600RR
that was my same reasoning, i said why in the hell would you move the vtec cross over point on a CTR intake cam because it engages way too beautifully from the factory!!!!! even better than skunk stage 1 type r copies......
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
It COMPLETELY depends on the application, EVERY honda vtec motor is deifferent. There is NO magic #. Don't mean to break your heart. The best engagement point is one that is linear on a dynograph, giving you a steady endless climb in hp and tq to redline. The best engagement point won't even be noticed, it should'nt even be noticed while driving.
im gonna guess at 47-4800RPMs????
owner/operator
owner/operator
No, Peak hp always stays the same. Vtec is just there to help change the cam profile for better air/fuel. It isn't a "power-adder" However if I left it at 4700 I would have had less HP before engagement, because the motor would have been choked for air.
And it is mere co-incidence that my engagement point was adjusted to 4400 rpm, as your friends. I know you know better than that man
Guest
Posts: n/a
Im not sure what you meant by "as your friends" and the coincidence thing.
But I don't see how lowering the vtec point helped your car... If it was allowing you better air lower, it would've brought your midrange hp up being as that your turbo is/was large, and requires a lot of flow.
I was making power all the way to my limiter on the stock motor and 6.5psi, had I been able to rev higher, it would've kept making power. Lowering VTEC IMHO is _generally_ not going to help things, especially on a stock head.
AIM: TurboedTrip
