need help asap!!!
Old Oct 26, 2003 | 01:13 PM
GearGrinder's Avatar
ridin high
Default need help asap!!!
i just recently bought a crx and was told the clutch was bad cause it slipped now i am hearing a metal to metal grind in the tranny and either the tranny is shot or there is no fluid in the tranny
can anyone possibly come take a look at it maybe drive it and listen to it? im located near busch gardens
thanks
nate
Old Oct 26, 2003 | 01:16 PM
98MODMTR's Avatar
TR Balla Donor Supreme
ya....I got some advice for you.
"The problem with socialism is that you eventually run out of other peoples' money." Margaret Thatcher
Old Oct 26, 2003 | 01:37 PM
ridin high
EAD top cop...lol
Own an APBT? visit... www.mypitbullpro.com
Old Oct 26, 2003 | 02:51 PM
Josh's Avatar
Dr. Doom
grinds when you shift or grinds when the car is in gear and cuising?
Old Oct 26, 2003 | 02:58 PM
ridin high
grinds when the car is in gear like a constant metal to metal sound....i personally think the tranny is gone or its bone dry on gear oil or tranny fluid
what do you think?
Old Oct 26, 2003 | 03:00 PM
Josh's Avatar
Dr. Doom
could be tranny fluid, have you checked it? if you don't know a whole lot about this, take it to a tranny place and see if they can identify the problem. but, it sounds more like a lubrication problem, check the fluid and top it off if needed.
Old Oct 26, 2003 | 03:01 PM
mtber's Avatar
a. tranny fluid
b. blown clutch disc, (Spring blew outa the clutch disk & is rubbing on the flywheel)
c. something is bad in you're tranny :-/
Good Luck.
Old Oct 26, 2003 | 03:34 PM
Josh's Avatar
Dr. Doom
here's a pic of what your filler bolt should look like. it's on the passenger side of the car. jack up the car, unbolt this, and see if gear oil runs out. if, none comes out add, till it does. you may also want to just drain the tranny, just to see what comes out. as you can see, Honda reccomends replacing both drain and filler bolt washers and using their gear oil, as it contains addatives for smother shifts. the service manual i used was for 96-2000 civics, but i can't imagine your tranny being too different.
Old Oct 26, 2003 | 03:36 PM
ridin high
thanks, and do i put the tranny fluid right into those holes???
thanks
Old Oct 26, 2003 | 03:40 PM
Josh's Avatar
Dr. Doom
a pic of what i mean by fill it till it runs out. but like a said, you may want to just flush what you have and put some new gear oil in there. if you are not able to use Honda MTF, 90W gear oil should work. The drain bolt on the tranny should be magnetic, so don't be surprised if you see metal shavings on the end of the bolt. get both washers from Honda, slap them on and fill up your gear oil, drive it and see how it goes. and i appreciate you asking me for help; i've never worked on a tranny before, i wouldn't want to screw up your shit. hope this helps. good luck.
