need help asap!!!
Old Oct 26, 2003 | 03:43 PM
GearGrinder's Avatar
ridin high
thanks so much for the help i really apriciate it!!! ill let you guys know what i find out
Own an APBT? visit... www.mypitbullpro.com
Old Oct 26, 2003 | 03:44 PM
Josh's Avatar
Dr. Doom
gear oil actually comes in a caulk like tube. you remove the filler bolt, and basically squeeze it in. it's practically impossible to overfill, unless you are able to hurry and put the filler bolt on . there are fancy devices that measure it for you, but it's not required; just fill it and let it run till it doesn't come out. to check it at first though, just remove the filler bolt and put a pinky in the hole and see if you have any oil on your pinky. hope this helps.
Old Oct 26, 2003 | 03:52 PM
ridin high
my pinky is fat i dont think that will work hahaha
Old Oct 26, 2003 | 03:53 PM
Josh's Avatar
Dr. Doom
use a q-tip or a pencil eraser.
Old Oct 26, 2003 | 03:58 PM
ridin high
haha that might work
Old Oct 26, 2003 | 04:10 PM
Josh's Avatar
Dr. Doom
you're welcome
Old Oct 26, 2003 | 06:24 PM
  #17 (permalink)
KJ's Avatar
KJ
bored at work
probably a main shaft bearing, or your clutch is worn to the point that the springs from the disk are grinding against the flywheel bolts.
