ls reving to 8?
Old Oct 20, 2003 | 04:58 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
Default ls reving to 8?
can this hurt? i mean my ls motor pulls awsome but it doesnt pull long enough. when i shift at 7 it feels like it could use a few more rpm in the begining gears. can i make it rev to 8 with the compression that i have. 11:4:1. and if its ok how much would this run me?
tamparacing.com
Old Oct 20, 2003 | 05:10 AM
spoonfed's Avatar
Tha numba one stunna
11:4:1 how did you achieve and diterman this ratio?
... content in sig not work friendly
Old Oct 20, 2003 | 05:13 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
i t was tested and i did it with a compression cal. online
wish my pms worked so i can tell you how i reached this
tamparacing.com
Old Oct 20, 2003 | 05:29 AM
spoonfed's Avatar
Yeah seriously because thats about where I want to be...
Old Oct 20, 2003 | 05:34 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
since we have the same motor, i'll just say that its beautiful.
tamparacing.com
Old Oct 20, 2003 | 05:45 AM
spoonfed's Avatar
All motor ls running 14's yeah I would say thats beautiful...
Old Oct 20, 2003 | 05:46 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
STOCK HEAD!!!!!
tamparacing.com
Old Oct 20, 2003 | 06:52 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
1991 ls motor. my block is FRESHLY rebuilt. i just hot 5700 miles on it. oversized jdm type r pistons, 2 layer head gasket, ummmm the head is stock internals. with 98 ls cams that are more aggressive and give a little more umph. im using a stock ecu that hits 7 grand. i feel great power from a dead stop to redline . as the same in 2nd 3rd and 4th. as if it want more rpm. i have a jdm b16 s1 tranny. gearing is awsome in there. i figure if i can get this bad boy to red line at 8 it would run a bit faster and put furure bolt on's to it max potential
tamparacing.com
Old Oct 20, 2003 | 07:36 AM
99B16Si's Avatar
the ls heads arent meant to rev that high. the bottom end will be fine to go to 7800-8000rpm. but the free floating rockers werent really designed to handle that high of rpms. ive seena lot of people over rev their ls heads and somehow the valve clearances will open up causing the head to make some nasty noises and they just gotta limp it home and do an adjustment.
