TECH: LS/VTEC Alternative...
Old Dec 1, 2003 | 07:06 PM
  #21 (permalink)
KJ's Avatar
KJ
bored at work
Yeah this is rediculous. A sleeved/bored b16a might work out for FI but it would be just about the last thing I'd do for a street N/A motor. Always go with the bigger motor.
Old Dec 2, 2003 | 06:48 AM
  #22 (permalink)
racin's Avatar
ZMR
Default yo
ZMRacin...for the people since 1998.
typeZ zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
Old Dec 3, 2003 | 12:21 PM
  #23 (permalink)
canIpiitb?'s Avatar
omfg!!!!!!!!! why are some people so scared of ls vtecs???
R/s ratio is important, but its not like the freaking bible to go by
building up a b16 like that will cost you wayyyyyyyy more then just buying a b18c or even a c5 shortblock!
just getting the crank will cost you freaking over 900!!
sure, when you need to rev the piss out of your engine constantly this might be a good build,(for racing maybe)
but most of us here on t.r. drive our cars on the street., where midrange torque is more important.( correct me if im wrong)
lsvtecs and b18c's are just as reliable as the b16s and b17s
it all depends on how you build your motor..
using correct tolerences and clearrences is most peoples problems
not bad R/S ratio!!
when would you rather have your torque and power??
ls/vtecs usually peak at around 7.5 to 9k rpm
i bet you that b16's with the same mods will end up being somewhere around 10k or 11k to generate the same amount of power( do they even make cams that go that high?)
and trust me, when you rev that high to make that much power, you will have more problems then those l/s vtecs with their "bad"
r's ratios (tearing down the head during every oil change must be fun!)
another thing id like to point out is b18s have a higher deck height
enough with this debate!
b16s suck that is all.......
nothing compares to a good ole merican v8
Old Dec 4, 2003 | 07:55 AM
  #24 (permalink)
Dabwuigwe's Avatar
Digga
What about building a straight up LS b18b1?
Old Dec 4, 2003 | 09:17 PM
  #25 (permalink)
canIpiitb?'s Avatar
nothing wrong with that!
Old Dec 4, 2003 | 09:43 PM
  #26 (permalink)
vertigo_16201's Avatar
Sure, if you are rich and wont miss low-end power
Old Dec 5, 2003 | 02:51 AM
  #27 (permalink)
Vito_Corleone's Avatar
TR Balla Donor Supreme
Why would you miss low end power?
Old Dec 5, 2003 | 05:56 AM
  #28 (permalink)
Dabwuigwe's Avatar
Digga
Yeah why would I be missing low end power? I feel like people often discount the LS non vtech's and i don't understand it.. I think its a great platform to start with..
Old Dec 5, 2003 | 06:03 AM
  #29 (permalink)
cams that make peak tq at 8000+ rpm will lose a substaintial amount of low-end and derease your car's as milage since you have air/fuel going straight thru the motor b4 it can be combusted due to the extreme overlap/lope. At this point, it is pretty much a race car.
Old Dec 5, 2003 | 01:26 PM
  #30 (permalink)
Dabwuigwe's Avatar
Digga
are you talking stock cams or just the LS in general?
