LS or GSR Tranny
Old Sep 21, 2003 | 03:51 AM
  #21 (permalink)
MattC's Avatar
Professional Asshole
gsr tranny all the way, its much shortier
Semper Fi
Aim and Yahoo- Inkedupordie
Old Sep 21, 2003 | 04:18 AM
  #22 (permalink)
60-1EK's Avatar
Engineer at the source
Originally posted by n20teg
with my 150 shot i had the gsr tranny first ,with it i would hit the juice and i wouldnt be able to shift fast enough , and the 1/4 i was shifting in to 5th,now with the ls in my car i get trantion at the top of 2ndi shift out of 2nd at 75 3rd tops 105 and in the 1/4 mile i never have shifted out of fours gear.so i am happy with it but if u do gsr na its good turbo or boost of some kind ,u will shift more offten,with ls u will be in boost longer getting more mph its all up to u ........
No. The myth about LS trans....longer time in boost...has been strung along for the longest time. The B16 trans or the Gsr trans is the best trans for boosted cars. If you can get the power to the ground, you will want to rip through them. You can put an LS 4th and 5th gear in the trans so you dont have to shift was you go through the traps and will also get good rpms/gas mileage on the interstate. Almost every quick civic....almost all the pro racers....all use Gsr or B16a trans.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Sep 21, 2003 | 05:51 AM
  #23 (permalink)
qitstrn's Avatar
Can you spot me 20 cars?
I agree with what you said till the end.With the power you are planning with your new turbo on the street LS is were it's at.The pros do use GSR trannys and the reason is this.They are using at the smallest a 24inch slick,most run a 26.With a tire that tall you need to gear it down.You are not running tires on the street that tall.The gear ratio is changed with the slicks.Different trannys work for different set-ups.There is no one that is best all around.You can see this by the different opinions.
Old Sep 21, 2003 | 06:24 AM
  #24 (permalink)
60-1EK's Avatar
Yeah, I will agree there. It is an entirerly different ball game when you get on street tires. Increasing rev limiters will counter act this though. 9k here I come.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Sep 21, 2003 | 07:13 AM
  #25 (permalink)
qitstrn's Avatar
It's hard to catch you you always seem one step ahead of the game!What diff are you running?
Old Sep 21, 2003 | 12:42 PM
  #26 (permalink)
60-1EK's Avatar
Your twin!
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Sep 23, 2003 | 10:22 AM
  #27 (permalink)
BERT-O's Avatar
yO!
Yep, 12.4 on a GSR tranny, 12.6 on a LS tranny, samewhat the same 60" foot time (.1-.25 difference), same height slicks, almost same temp and track conditions, reaction time, same driver, etc, etc.
What was different was the MPH only!
