Junkyard Engine?
Old Sep 10, 2003 | 08:34 PM
rangcrx's Avatar
engine building &best
how would a 86-89 integra motor drop right into a 89 crx i need to no?please this is new to me all the mounts are different axels and exhust let me no
i love AUTOZONE
Old Sep 10, 2003 | 08:39 PM
mtber's Avatar
read what i posted....
wiring & ecu wise it would probably be cake since you're going pre obd to pre obd
Old Sep 10, 2003 | 08:44 PM
mtber's Avatar
Originally posted by LS_ken-e
nope. the 86-89 teggys sucked, but it will drop right into your crx. your call. those old motors might be a little cheaper
What he was trying to say here is...
86-89 motors use the same injectors, distributor, alternator etc..
hence you wont have a wiring job to do, only mounts
if you want an easy swap into a crx, buy a zc motor it and boost it
go to homemadeturbo.com there are tons of single cam home made turbos there to look at...
Old Sep 11, 2003 | 04:06 AM
BitbyStreetRacin's Avatar
once your bit, your done.
oh i definetly am going to DOHC. i just dont know which swap to do and if i can get a good block from the junkyard and build it up, i would do that. could i get the b18a bottom end, and find maybe a b18c head? or soemthing along those lines...more power is always better...
Old Sep 11, 2003 | 05:23 AM
that sounds like the way to go! how much should i pay for a bottom end?
Old Sep 11, 2003 | 07:30 AM
  #17 (permalink)
mtber's Avatar
ls/vtec is a great way to go... but you might be better off in the long run with a gsr motor w/ some minor mods like a intake manifold & some cams.
reason i say this is...
lsvtec can get expensive compared to a complete swap
lsvtec wont last as long 50% of the time because of it's high compression
to each is own.. i say go lsvtec in a crx... fun fun
Old Sep 11, 2003 | 07:48 AM
  #19 (permalink)
mtber's Avatar
heh....
why would you build an ls/vtec setup w/ stock ls pistons ?
you would be shooting you're self in the foot.
you would want atleast jdm b16 or ctr pistons with an ls crank & rods in a 1.8 block.
