Motor Build Up!
Originally posted by Cronic
Dave: I believe the process is Sleeve -> bore to 84mm. The sleeve will be thinner, as we cannot bore out the outer walls themselves.
Guest
Posts: n/a
Zee, They are thinner, but they're still stronger then stock, and can support boost. I think GEM would be better fitted to answer the question on how much psi they can hold.
I've been looking into it but not enough...Are their any Pro Drag Cars running GE Blocks? I think that only street cars are running GE blocks...Any reason behind that?
Zee
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
Guest
Posts: n/a
3d B3|2g4|\|h0l7z |24|\| G3 1|\| h15 C|2><.
L154 Kub0 h4d G3 1|\| h3|2 C1v1c
M057, 1f |\|07 4ll 0f 7h3 b1g guy5 4|23 |2u|\||\|1|\|g 83mm b0|23 0|2 l4|2g3|2. 5h17 1 h4d 0|\|3 70d4y 7h47 \^/45 4 85mm b0|23. G3 15 0|\|3 0f 7h3 l34d1|\|g 5l33v3|25 1|\| 7h3 U5.
0h y34h 4|\|d 175 0u|2 p|21m4|2y c0mp4|\|y \^/3 u53
Guest
Posts: n/a
y0u k|\|0\^/ 0|\| 53c0|\|d 7h0ugh7 175 p|2377y much \^/0|27hl355 70 m3|\|710|\| \^/h0 |2u|\|5 \^/h47, b3c4u53 4ll 7h3 5l33v35 0u7 7h3|23 4|23 p|2377y g00d 3><c3p7 f0|2 B3|\|50|\|'5. \^/hy 15 17 \^/0|27hl355? 5p0|\|50|25h1p 5k3\^/5 50 m4|\|y 57471571c5. 1MH0, 1 |24|\|k 7h3m l1k3 7h15:
G3
43B5
D4|270|\|
|25 M4ch1|\|3
4l7h0ugh y0u |234lly \^/0uld|\|7 g0 \^/|20|\|g \^/17h 4|\|y 0f 7h3m.
G3
43B5
D4|270|\|
|25 M4ch1|\|3
John whats wrong with Benson's. I know someone with them in a build b20vtec turbo and he said they are very good sleeves.
I have not heard to much about AEBS..
Im The Original Crab!
