Fix my hatch, win $100!!!
I replaced the same harness when mine went out but that didnt seem to fix the problem you need to trace those wires they all lead to the fuse box. Sounds like your problem lies there in between the wires and fuse box. check for power on one side then check the other side. If you do find that the current is not makeing it past the fuse box wire it directly.
from what i hear i no its not his starter 100%
i love AUTOZONE
i love AUTOZONE
its not the starter . its not the starter relay (i removed it and used it to start my car)
the car started previously but had ignition problems so that was replaced and now it does not start at all. there are various relays under the hood (3 i believe) that are clicking when you turn the ignition to the "start" position. If your familiar with this chassis its the relays on the passenger side by the headlight, and on the inner fender just in front of the fuse box. I have no idea why these relays would be jumping ??
