Fix my hatch, win $100!!!
My hatch will not start. I replaced the ignition switch, and the relays. When I try to start it, all it does is click. When I first got the thing together, it was trying to start in the second key position, there was wiring that was spliced, I guess for an aftermarket alarm. So I returned all the wires back to their stock location. I turn the key and now the starter solenoid just clicks. If you can get my car to start like it is supposed to, you win $100.
have you tried tapping on the starter with a hammer while turning the key it may just be a flat spot on the starter try it i had the same problem it will eventually work its self out usually let me know
collision and refinising technician need bodywork/ paint call 727 776 7830
I am starting up a newly installed motor, so I don't really want to pop start it. I haven't tried hitting the starter with a hammer, but I guess I could try that. The starter doesnt even turn, it just clicks. All of the cables and such are secure. I believe this is more like a wiring issue, but I don't have the tools to test wires, or the knowhow of what I am testing for.
apply direct current to the starter and see if it turns over if so then you have a bad starter signal. Mines did the same thing after i did my swap it was the cable from the ignition to the fusebox(think yellow cable with black line). Check to see it that works. youll need a volt meter to check to see if the ignition switch and starter are getting a signal
WAS THE CAR A %SPEED OR AUTO WHEN YOU FIRST GOT IT?
i love AUTOZONE
i love AUTOZONE
