stroker kit ???
Old Jul 15, 2003 | 08:40 PM
boostedb16a3's Avatar
Equal Opportunity Hater
STFU!
as for the stroker kit dont do it. especially if u wann go boost. ur walls are gonna be so thin. a friend of mine has a stroked gsr to a 2.0 and he is running 12 psi. that is the most he can get out of it and he is worried how much longer it would last. he runs 12.4 thats pretty fucking slow considering the 2grand he dropped on the stroker kit alone. just my 2 cents
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Originally Posted by JAVIELITO
limpio as fukk
Old Jul 16, 2003 | 05:55 AM
KJ's Avatar
KJ
bored at work
Any stroker kit ona stock deck height motor will create severe angles and produce a significantly greater side load on the cylinder walls which can blow them out. The load on the bearings is also increased. This is not good for a street motor. If it was a race motor and longevity isn't an issue then go for it but then you will run into piston speed, acceleration and VE issues that are not even worth going into now.
If you want a 2L then go with a sleeve and overbore.
Old Jul 16, 2003 | 07:36 AM
T61turboII's Avatar
thanx for all the info the stroke kit is out the window... ill see if i can think of nother set up to go with... kj i pmed you....
Old Jul 16, 2003 | 09:49 AM
  #18 (permalink)
Crab Cakes's Avatar
So Lost!
i would not stroke it...i would have some aftermarket sleeves put in it thats all ans bore it to 84mm.......i have had a couple of friends with stroker kits and i have not much noticed a difference at all........
--george--
Im The Original Crab!
Old Jul 16, 2003 | 10:45 AM
  #20 (permalink)
MotorMatrix.com's Avatar
if you are going boost run it stock bore. i wouldnt even go 84mm. the little bit of extra tq gained is not worth the risk with the thinner walls. i have made 559@22psi on stock bore and stroke type r and also well into 600's at 29psi. i wouldnt buy a stroker kit unless going all motor and i still wouldnt buy the kits out there. i would get a golden eagle deck plate and order custom stroke rods and make your own kit. that would get you to a 2.1+L.
Mike
MotorMatrix.com
R.A.W Racing
1.877.84.Motor
SFP.net
99' Civic Si NHRA Street Car 10.36@144mph 2850lbs w/ Driver
96' Civic NOPI Street Car now Sponsored by SFP. 2325 w/ Driver
