stroker kit ???
Originally posted by Cronic
The point of taking it to 84mm would be to sleeve the block, so the walls will be just as thick as stock, and able to hold 40psi from GEM.
Mike
MotorMatrix.com
R.A.W Racing
1.877.84.Motor
SFP.net
99' Civic Si NHRA Street Car 10.36@144mph 2850lbs w/ Driver
96' Civic NOPI Street Car now Sponsored by SFP. 2325 w/ Driver
Mike
MotorMatrix.com
R.A.W Racing
1.877.84.Motor
SFP.net
Guest
Posts: n/a
Originally posted by MotorMatrix.com
at 84mm the walls are not as thick as stock. the difference between GE sleeves and stock are not the thickness. they are ductile iron so they wont split. also, if you go 84mm and you happen scratch the sleeve you will have to resleeve is most cases. at 81mm you can bore it over 2-3 times and still run boost.
-Keith
sure you can run 84.5 or even 85mm i have seen. most times when you hurt the walls it will need to go .040 over. In a street car though i dont see any reason to go over 81-81.5mm bore to start out. the gains are not worth the risk in my opinion.
Mike
MotorMatrix.com
R.A.W Racing
1.877.84.Motor
SFP.net
Mike
MotorMatrix.com
R.A.W Racing
1.877.84.Motor
SFP.net
yeah, the sleeves come 84mm from darton but it still has the same wall thickness. you cant make a sleeve thicker when they already touch.
Mike
MotorMatrix.com
R.A.W Racing
1.877.84.Motor
SFP.net
Mike
MotorMatrix.com
R.A.W Racing
1.877.84.Motor
SFP.net
