compression test?
Old Jul 15, 2003 | 03:48 PM
Miles's Avatar
It's a wooden pickle.
Default compression test?
can anyone walk me through how to do this? i got a kit to do it, but it looks like the only directions with it are written for a carbed v8... not sure exactly where to go from here... help? thanks
Old Jul 15, 2003 | 05:58 PM
Josh's Avatar
Dr. Doom
take the spark plug out of the cylinder, put the hose down where the spark plug was, disconnect plug wires from the distributor and turn over the engine till you the needle will not go up anymore on the guage. i think that should be it, not sure if you have to do anything with the fuel line.
Old Jul 15, 2003 | 07:34 PM
mike34655's Avatar
Member
That sounds about right.
Old Jul 16, 2003 | 03:56 AM
Bill's Avatar
Livin' in Seattle
Originally posted by `92CXhatch
you dont need to do this... trust me... never had any problems before...
-Keith
Just take the time to do it right and simply pull the fuse. It takes two seconds and then you don't have gas sitting in the cylinder and stinking up the garage.
Also I didn't see mentioned anything here about leaving the throttle WIDE open. So I will write the steps:
1) Disconnect Fuel pump fuse
2) remove plug wires
3) remove spark plugs
4) screw compression tester into spark plug hole
5) either block the throttle wide open or simply jump into the driver's seat and keep your foot on the pedal
6) turn the ignition and crank the motor seven times. Seven seems to work the best.
7) get out, check gauge, repeat three more times.
You might also want someone to monitor the gauge while you're cranking it as the way the cylinder builds pressure can also help in troubleshooting.
