compression test?
Originally posted by Cronic
Please remember to disconnect your fuel pump fuse, as to not flood the engine, also. Turn the engine over the same amount of times for each cylinder.
Thanks.
Thanks.
if you remove the ecu fuse, the ecu will have no power and injectors won't work, grab whatever fuse makes you happier
Gracie Barra Clearwater
