tranny
Old Nov 25, 2001 | 01:10 PM
obituary's Avatar
TR OG
? do i stick with a th350 or the 700r? i know the 350 is stronger but with 4.11 gears the 700r 4 will save on gas and give me good top speed
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
Old Nov 25, 2001 | 03:38 PM
HybridSS's Avatar
I have fuzzy eyebrows
What do you have in there now. Engine/tranny combo? HP/TQ? Rear Gear? Tires? Weight of the car? Power adders?
Where will you end up?
Do you drive it everyday?
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Nov 26, 2001 | 05:28 AM
stangerang's Avatar
whoopdy fucking do!
stay away from the 700r4 and 4l60e they are weak as hell get the th350 or a 4l80e--(out of vette) they are much stronger---if you want a fast car you shouldnt worry about gas---also dont run such a high gear----you can still be really fast without a high gear in the rear....
200 points away from a 300
Old Nov 26, 2001 | 03:32 PM
ZDriver96's Avatar
I wouldnt run that small of a final gear ratio with any automatic if you plan on using it for street use.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Nov 28, 2001 | 08:08 AM
obituary's Avatar
TR OG
3200 lbs novaSS about 450 hp and 460ft lbs 4.11gear in the rear.its fine like it is but on the highway it sucks 3000rpm at 60mph 4000rpm at 80mph windin at 100 .dont know what stall 2500 or 3500 ? and runnin a higher gear is out ....higher gears whith a high stall takes forever to go unless i stomp it!!!!
1972 nova ss
89 240 sr20det
X CVC
Feb 22, 2001 08:46 PM
RicerX
Feb 22, 2001 06:57 PM
TampaTraps
Feb 11, 2001 01:02 AM
93ex
Jan 9, 2001 07:56 PM
gsx eclipse
Aug 27, 2000 09:07 AM
