pontiac trans sport van problem
Old Jul 12, 2007 | 09:19 AM
psychx's Avatar
Default pontiac trans sport van problem
im workin on a pontiac trans sport van,
just put new fender on it, new bumper, new axles, etc.. was in a wreck.
everything works now and it runs strong but smokes... what would be the cause of this? should i change all the oil out and put a new filter on?
any help appreciated, also the battery seems dead but i jumped it and it came right on, shold i just let the engine run for a while?
Old Jul 12, 2007 | 11:52 AM
BLUE2KSS's Avatar
Mechanical Engineer
smokes on start up only, or still while running?
what color is the smoke?
Old Jul 12, 2007 | 11:55 AM
Pdubinator's Avatar
White girls suck;)
if it smokes all the time your burning oil or your piston rings are screwed.
Old Jul 12, 2007 | 04:35 PM
psychx's Avatar
it smokes when i start it but i notice every once in a while while its running a little comes out, it has sat for a long time tho
oh and i forget i think its similar to the smoke in ur sig - just not from peelin
Old Jul 12, 2007 | 09:45 PM
BLUE2KSS's Avatar
Mechanical Engineer
if it smokes on start up its most likely valve seals or valve guides
and the smoke in my sig looks more bluish, therefore its oil and not just carbon or anything else
so its either what I said or Pdubinator, but like he stated its more if its doing it all the time
do a compression test, and a leak down. that will be able to differentiate much better than our guesses online, and what color the smoke might look ya know what i mean
Old Jul 13, 2007 | 07:35 PM
psychx's Avatar
yea thanks man i was just tryin to get a quick answer on it, you guys helped me out if i have any other questions ill post it here
