LT1 Project....Headgasket change...progress with pics inside...
its good to replace the lifters, since most people doing cam installs are doing them to untouched stock shortblocks.
if you have a stock setup...and you dont mill the head, you should be just fine with 7.2" OEM pushrod lengths but its always good to check before you go ahead and do it. the tool is like 20 bucks i think. if you go with a higher lift cam, get springs. personally if your on a budget, spend like 500 bucks and get the LT4 hot cam kit, it comes with everything to convert it over i believe, and it is decent gains.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
