LT1 Project....Headgasket change...progress with pics inside...
Old Aug 1, 2005 | 07:14 PM
  #31 (permalink)
EliteZ's Avatar
Precision Motorsports
lol Phinger, it just means that is a semi mild cam, a little above a stock Corvette (old times). I dont know alot, but isn LSA cams for LSOnes?
448WHP/420WTQ
Full bolt-ons+H/C
Car Sound Clip & More(W/ Mekanic)
Tuned by Precision Motorsports
Old Aug 1, 2005 | 07:33 PM
  #32 (permalink)
formula69's Avatar
blowed up
kenny we might just have to build up heads cam lt1s together..
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old Aug 1, 2005 | 07:39 PM
  #33 (permalink)
Tackleberry's Avatar
Animal Mother
wanna do mine? lol
i really just want it to run smooth, good, and have a lil more at the pedal.
Old Aug 1, 2005 | 07:41 PM
  #34 (permalink)
formula69's Avatar
blowed up
ill take a look at it.. i gotta get in touch with my machine shop to get the heads looked at.. they are probably warped pretty good where are you located?
im FAT!!!!
Old Aug 1, 2005 | 07:49 PM
  #35 (permalink)
Animal Mother
im in carrollwood. im probbaly gonna be pulling them off sunday night...if...i gotta have someone come down to me to pull both off at the same time because i cant get the back tube off, so im gonna pull them off simutanieoulsy and level, then remove the back tube, and reinstall the heads the same way. im not really in a rush because im gonna replace the matching lifters to the cam so it runs better overall and reduces that noise they are making from the upgraded cam.
Old Aug 1, 2005 | 07:54 PM
  #36 (permalink)
Sneakin Deacon's Avatar
PSSHHH x2
the AD is advertised duration, its what gives a more accurate profile of a cam compared to people going by .05" lift numbers. shows a more accurate ramp rate.
anywho, 488 lift is with a 1.5 rocker i presume. sounds like a cam with tad more duration, but keeping the lift minimal to utilize stock parts.
LSA referse the lobe seperation angle. IC refers to intake centerline. if memory serve me, a cam with 114+4 means the cam in general is on an average 114 LSA, but the +4 indicates advance, which means the intake valve is actually on a 110 LSA, and the exhaust valve is on a 118LSA
and scott, im doing a H/C setup right now. just waiting on it to get here. i couldnt really decide what route to go with, so im going solid roller. gunna get the block partially filled, and splayed mains. hoping she can stay together to 7500, but will only go to 7 to keep safe. i had to go tamer on the cam, anything else makes too much usable power past that for me to waste.
as for being cheap etc, with the heads..i dunno what you have to spend, if you have a decent amount like 1500 or so, i would say go buy a set of lloyd elliot stg 2 heads, and he has a cam for it aswell. seems to have proven to be a solid setup.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Aug 1, 2005 | 10:01 PM
  #37 (permalink)
formula69's Avatar
blowed up
well i got an lt1 block.. so im probably just gonna build up a 355 with heads and cam.. something streetable maybe around 450 hp.. lloyd has good packages but im probably gonna go with a set of afr lt4s and port them out and just get a cam made for it based on flow numbers
im FAT!!!!
Old Aug 2, 2005 | 04:48 AM
  #38 (permalink)
PSSHHH x2
the bolts on that coolant line are like 9/16 - 14/15mm i was able to get them off in the car...might wanna try putting a wrench on one and banging the hell out of it with a hammer.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Aug 2, 2005 | 04:52 AM
  #39 (permalink)
PSSHHH x2
well if you have the $$, and can find someone to do it. find a set of old 12* SBC heads and have them converted to reverse cooling, get them worked over big time, find a suitable cam, there is no reason you shouldnt make 500+ N/A
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Aug 2, 2005 | 10:25 AM
  #40 (permalink)
???'s Avatar
Capt."Howling Mad"Murdock
i've never heard of this? you have to match the lifters to the cam in an lt1?
odd
