HELP car is broken... once again..
well the car runs and drives great... shows no codes...
give it partial throttle let it run up to 4k and the E brake light comes on and the car starts to miss..
my thoughts on this are.. I'm running an open y.. and the exhaust gases are hitting the E brake line making the car think that the E brake is being pulled and that is pulling timing out of the car and shuttin it down..
could this be anything else? also the tach will skip a few hundred RPMs or not read up to speed with the actual RPM
Totalled his shit!@
Totalled his shit!@
Tach signal is taken from the cam position sensor at the back of the block. The brake light can be either brakes, anti lock brakes or E brake. Check over your wiring real good
Have you dont any work on the car lately?
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Originally Posted by corey r.
uh oh... an LS1 with problems... hurry delete this before it ruins our track record.
atleast you're honestoh yeah btw, I had to help him out the other day when
(cover your ears LS1 Gods/lovers/nuthangers)
..................dum dum dum....HIS CAR BROKE DOWN
yes the LS1 was on the side of the road...
this all started after I decided to run an Open Y pipe..
and its only at like 75% throttle and over 4500rpms it will miss and the brake light flashes..
Totalled his shit!@
Totalled his shit!@
