No spark to ingnition coil...
ummm... your talking about taking a hammer to a balancer pulley.... Balance.. as is weight distributed evenly..... if u do make sure its a rubber/plastic tip mallet... Ive taken em off many times.. using a pulley puller is alot easier.
u cant mess up TDC... u can only mess up the balance of the Crank and the location of which the arrow points which can affect rocker adjustments if u choose to use the arrow as a way to determine TDC... Just do what i say so u do it right
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
"SLOW LT1"
Blue 2005 Acura TSX
Go to autozone, rent a balancer puller. If u use a hammer you'll get tired, annoyed, and pissy. LIke i said.. just make note of the arrow position when u take it off. and for some reason if u dont have an arrow just use a pencil to mark the way it came off.
"SLOW LT1"
Blue 2005 Acura TSX
"SLOW LT1"
Blue 2005 Acura TSX
it only lines up one way. the bolt holes arent even.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
