LT1 Pro and Cons?
lol Well, where can I get LT1Edit, and wouldnt I need a 100 dollar connector cable for a laptop to use it?
Also Ill try to be there Wednesday, I am off work. Got to get the money to go lol. i try to get there very early to get the most runs in like right when they open (530)
448WHP/420WTQ
Full bolt-ons+H/C
Car Sound Clip & More(W/ Mekanic)
Tuned by Precision Motorsports
448WHP/420WTQ
Full bolt-ons+H/C
Try hard i wanna run you.
LT1 vs LT1
^^Makes me warm and fuzzzzy
DynoJet huh? How much does that one cost to use? What is the Factory WHP for my car. Thanks for the lengthy explanation of what rods and crankshafts are. I do know all of that already. As to the crediability of Hooker about there WHP gains, you could be correct, and probably are but in the mag it said WHP not HP. And I know ur example shows 10-30 HP loss. to the WHP from HP. Seems like very little compared to how everyone else exaggerates.
They say the 02 SS is fastest Camaro Chevy ever made. back in 70s they had 350CI with 350HP on the motor, ur sayings my LT only might have 285. That comparison seems weird unless back then they used Lead Driveshafts and all?!!
-Vince
-Vince
heh. cool. I also got one more question. I thought EFI cars were created to replace Carburated cars for more mileage, fuel delivery efficientcy and minor performance gains. Like I was arguing before, now I am just asking to help me compare. Old 1979 Z's had 350CI 350Engine HP. They had Cast iron heads and all the get up. LT's have ALuminum angle plug heads, aluminum intakes, EFI and all these sensors to help monitor and increase engine efficientcy. What is it about LTs that make them not up to the old nestalgias?
448WHP/420WTQ
Full bolt-ons+H/C
448WHP/420WTQ
Full bolt-ons+H/C
Originally Posted by Jakethesnake
pro's- you are not a LS1 owner and prob wont have your head stuck up your ass (j/k!!)
con's-you have ppl like Sneaken deaken and 97BlkZ as fellow owners which I would be ashamed of!! j/k again
they are cheap to buy, not bad to build, getting to spakr plugs sucks so much though its gross, I am not a fan of lt1 z's looks but I do really like the Vete;s and of course the TA's (the ws6 hood never gre on me)
quickrice: if you recommend hypertech again, I will have to start posting that I will kick ppl in the ball's for $$$. I highly recommend ls1tech or ls1.com (if it still is up) and their lt1 forum's. A lot more truthful knowledge can be found there then someone that does not own a LT1 or really know about them. It would be like asking me about a rotary, I have no clue about them. If I had gains like that on my car, I would be sitting well over 1k in hp right now lol. I like LT1's and do like the idea of built ones. Call Alan Futral if you ever want some real performance stuff for the car, I am sure Datruth or Gator has his number.
ls1=unstopable!!!!!!!!!!!!!!!!!
1979 Engine & Drivetrain Info
CID Config Bore & Stroke BHP @ RPM Torque @ rpm Comp Carb.
L-22 250* L-6 3.875 x 3.53 90 @ 3600* 175 @ 1600* 8.2:1 1V
L-22 250 L-6 3.875 x 3.53 115 @ 3800 200 @ 1600 8.0:1 1V
LG-3 305* V-8 3.736 x 3.48 125 @ 3200* 235 @ 2000* 8.4:1 2V
LG-3 305 V-8 3.736 x 3.48 130 @ 3200 245 @ 2000 8.4:1 2V
LM-1 350* V-8 4.00 x 3.48 165 @ 3800* 260 @ 2400* 8.2:1 4V
LM-1 350 V-8 4.00 x 3.48 170 @ 3800 270 @ 2400 8.2:1 4V
Z-28 350* V-8 4.00 x 3.48 170 @ 4000* 265 @ 2400* 8.2:1 4V
Z-28 350 V-8 4.00 x 3.48 175 @ 4000 270 @ 2400 8.2:1 4V
* denotes California and high-altitude ratings.
Drivetrain Information
Engine Auto Manual
Yr Model Trans code/type CR Displ. HP Torque Induction std. opt. std. opt.
93 Coupe
Firebird A4,M5 L32 V6 9.0:1 3.4 (207) 160@4600 200@3600 SFI 3.23 ---- 3.23 ----
93 Z28
Formula
T/A A4,M6 LT1 V8 10.5:1? 5.7 (350) 275@5200 325@2400 SFI 2.73 3.23 2.73 3.23
94 Coupe
94 Z28
Formula
T/A A4,M6 LT1 V8 10.5:1 5.7 (350) 275@5200 325@2400 MFI 2.73 3.23 3.42 ----
95 Coupe
95 Coupe
Firebird A4,M5 L36 V6 9.4:1 3.8 (231) 200@5200 220@4000 SFI 3.23 3.42 3.23 3.42
95 Z28
Formula
T/A A4,M6 LT1 V8 10.5:1 5.7 (350) *275@5200 325@2400 MFI 2.73 3.23 3.42 ----
*California Dual-Cat cars (automatic only) made 285 hp
Really? Well than I was wrong lol. I always thought that old 350s had 350 Horse
448WHP/420WTQ
Full bolt-ons+H/C
448WHP/420WTQ
Full bolt-ons+H/C
I was wondering about that because I remember the 77-79 had 200/220/190hp in the pontiacs but I wasn't sure about the chevys
as for this you gotta remember this is a GM tranny that actually transfers power
most dyno around 245-260rwhp
Originally Posted by TheShow50h
You lose about 15-16% in a manual transmission car from the crank to the tires. So if your car had 270hp, it would be more like 225-230rwhp.
Oh one more question. Is that WHP you posted or Engine Dyno HP?
448WHP/420WTQ
Full bolt-ons+H/C
448WHP/420WTQ
Full bolt-ons+H/C
