LS1 turbo 403 1329 flywheel HP
So you lock this after a lengthy spewing of bullshit and expect me not to reply...riiiight
So Who is the one who cant handle the heat??? Looks like its you onec again peckerhead.
I have already told you...you will get back ALL the BS you post. Not one bit less. And seeing as how I rarely EVER have any problems with any other members...and you are constantly in long winded pissing matches with multiple members...id say the problem is you!
You dont see me in the Ford Forum posting trying to trump anyones and everyones post.
As far as PMs...that goes both ways dickhead. You could have just as easily posted all of the above in a PM now couldnt you?
for the future...it goes like this....Scott posts BS...Al calls him on it. Dont like it...keep your mouth shut! If you can stick to that we will not have more problems.
So Who is the one who cant handle the heat??? Looks like its you onec again peckerhead.I have already told you...you will get back ALL the BS you post. Not one bit less. And seeing as how I rarely EVER have any problems with any other members...and you are constantly in long winded pissing matches with multiple members...id say the problem is you!
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Guest
Posts: n/a
You decided to go off the deep end first again so (which amazingly always gets overlooked) of course I was going to give you the reply you were looking for, if I didn't then of course you would say I couldn't handle it.
Who locked what ? Here os what the control panel says:
Thread closed by HybridSS on 09-10-2004 05:54 PM. Thread opened by HybridSS on 09-10-2004 05:43 PM. Thread edited by Scott on 09-10-2004 05:34 PM.
I edited my thread for some spelling errors after the fact but do you see "locked" by my name ?
Go check it for yourself.
Feel free to PM me that shoe in your mouth.
I did not intitally close it. I opened it...then closed it after my reply...just like the log you posted sais.
Bottom line is....you come in the GM forum Knowing you will stir up shit with your BS slanted posts and expect a reaction. You even said so in several posts. You want a reaction ...you will get it everytime. Until either the Admins kick you out of the GM forum or they kick me out as a GM mod.
Easy solution is for you to stay out unless you can control yourself.
nyways...about the project motor
Thats some serious Tq and HP at 5000 rpm. I bet that was a scary spike!
.Another note that is of some interest.
When we first hooked up the boost controller the lines were reversed causing a massive overboost. So here are some numbers from 5000 rpm at 36psi!
1594 ft lbs@5000
1517 hp@5000
Not sure how long it would hold that level but it sounded cool!!
1594 ft lbs@5000
1517 hp@5000
Originally posted by qitstrn
I thought you guys just fight and break balls with the import crowd. Glad to see everyone on TR hates each other. I feel much better now.
you have no idea.....
ford vs. chevy is life and death to a lot of ford guys.
