I want a Swap
Originally posted by Acidtalons
Pretty low mileage it sounds like. Less than 6000 a year.
If your looking to do it cheap you could go carbed on a first gen small block.
http://www.chevyhiperformance.com/te...es/0304_zoops/
I recommend that, lol. That motor might not actually work for towing in the low end, but you could build it for $5500.
Actually an LS1 swap would probably be cheaper as he wouldn't have to change as much and he can get a take out for $3500 or so....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2437105053
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
GM had a few factory extremes with LS1's as an option. and yes LHT is the place to get it done if you want something like that. id say, if you could, put an LS6 in it and be done with it. as far as auto or stick...id go with auto just because its more consistant. but what about the rear end? is it going to handle all of the new found torque?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
yea, well sticker price as i was told was in the 30's
id buy a vette for that price.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Originally posted by ilegalsrtracin
I put about 15,000 miles a year.... Sometimes when I take my boat out I go realy far wich adds an assload of miles, will this have an effect on my truck with the swap???
Not really, just if you build a motor keep towing in mind when you select a cam.
Vehicle Repair/Maintenance and TIG welding services for hire (steel and Aluminium), PM or IM me
AIM: Acidtalons
AIM: Acidtalons
Originally posted by PiercedJD
why a 6 speed and not an auto? in a truck........ where traction is automatically a problem, why would he further want to add to the inconsistancy of it?
6 speed install in a truck is a bit of a hastle too as far as shifter location ( especially if it's a standard cab) and clutch pedal mounting if it was a factory auto truck.
it's his money though.
