Bending Brake Lines and Creating Inverted Flares on Brake Tubing
Old Dec 1, 2024 | 09:00 PM
Default Bending Brake Lines and Creating Inverted Flares on Brake Tubing
https://www.classiccarrestorationclu...-tubing-008473
Mark Simpson
Already a member?
Current Time 5:58
Duration 6:00
Duration: 6 mins
Description
Cutting, bending, and creating inverted flares on brake lines is a necessary skill when building a classic car. Mark Simpson takes us through the process step by step so you’ll be prepared to build your own custom brake lines.
Old Dec 1, 2024 | 09:12 PM
Default Keep Brake Line Fittings in Place....from sliding away from the ends into the middle
https://www.classiccarrestorationclu...n-place-037209
Description
In the early years of the automobile, brakes were typically mechanical and operated by a lever or pedal that applied pressure to a series of rods and cables to engage the brakes. These systems were often unreliable and required significant physical effort to operate effectively.The development of hydraulic brakes can be attributed to Malcolm Loughead (later changed to Lockheed), who patented the hydraulic brake system in 1917. This system used a master cylinder to generate hydraulic pressure and transmit it to the wheel cylinders, which applied the brakes. It provided more consistent and reliable braking performance compared to mechanical systems.
The first production car to feature hydraulic brakes was the 1921 Duesenberg Model A. This marked a significant advancement in automotive braking technology, as hydraulic brakes offered improved braking power and better modulation, making driving safer and more comfortable. Throughout the 1920s and 1930s, hydraulic brakes gained popularity and became more widely adopted in the automotive industry. Various companies, including Lockheed, Bendix, and Dunlop, contributed to advancements in hydraulic brake technology, refining the design and improving performance.
Thanks to these early pioneers and manufacturers the evolution of the automobile became safer and more reliable, but their innovations have largely remained mostly unchanged nearly a century later. That includes the need to bend and route brake lines from a master cylinder to each wheel.
Bending brake lines can be fun and rewarding but sometimes it can be equally frustrating. One of the biggest frustrations occurs when you have bent up the perfect brake or fuel line and realize the fitting that should be at the end of the tube has somehow migrated to the middle or even the other end of the line. Most often the line needs to be straightened to slide the brake line fitting back to its correct location. Yes, it can be done but re-bent lines never look quite as nice the second time around. Mark Simpson shares some helpful tips to keep those brake line fittings in place while bending lines.
Jan 7, 2020 04:46 PM
EnsenCorp
Mazda Tech
16
Sep 24, 2008 05:25 PM
88EFSiR1J1
Feb 14, 2002 03:29 PM
