You Be In Some Deep .........., Boy!
Old Feb 21, 2012 | 03:47 PM
  #21 (permalink)
Empire's Avatar
buildin' it
Originally Posted by Graves
mine went from a huge gaggle fuck of piping to a smooth 3" piping lol. stock motor i got at least 10-15 hp so the dyno numbers show on test vehicles.
gaggle fuck. lol.
i know exactly what you're talking about.
Old Feb 21, 2012 | 04:55 PM
  #22 (permalink)
CoRDiTe's Avatar
Not Mad
Originally Posted by Empire
TR needs a "sarcastic tone" font.
The smooth piping does help, the faster the air comes in, the better. The cone style filter does allow for better air flow as compared to one of the flat style ones. Typically, they are made of a more efficient material compared to the paper of the stock ones. That's why an intake set up usually adds a few horsepower.
Those cone filters or flat filters doesn't matter. It matters from the material it is made from. If it has a material that allows for better air flow then it will give you better air flow. Just because you have a cone filter doesn't mean it's any better than a flat filter.
The concept of a cold air intake start off as a way to draw in air from outside of the hot engine bay, in a more efficient manor than trying to pull it up from the wheel well like the stock set up does.
Every car I've owned including my trucks stock OEM intake system draws air from the outside. I've never seen a car that draws air from the engine bay except for very old cars. If you follow the intake box(where the filter rests) you will see it is connected to a plastic pipe that draws the air outside through a hole in the bumper. Those so called cold air intakes the kids buy and stick them in their car are only for looks IMO because you are drawing the air from the engine bay. Hot air. You may get more air, but the air won't be any less dense than it is outside. So you aren't really going to burn cooler oxygen.
And everything you just said after sounds like you took it from a txt book and just copied and pasted. Just saying..
Old Feb 21, 2012 | 05:57 PM
  #23 (permalink)
Empire's Avatar
buildin' it
surface area plays a significant role in how much air a filter passes through, considering the force pulling the air through the filter doesn't change.
A cone shaped filter made out of paper will flow more than a flat panel style paper filter.
The material it is made out of just takes it a step further in increasing the efficiency.
Yes, most stock systems pull air from outside of the car. Usually from in the wheel well.
The difference from the stock set up and an aftermarket set up is that the stock one is very constrictive. That small tube that goes to the wheel well or as you said, in the bumper, doesn't allow much air to flow through it easily. This makes the engine have to work harder just to get the air it needs to run. There are various reasons the manufacturers do this. Combination of eliminating the noise a larger intake makes, to controlling the power curve, to lowering the chance of sucking up things like water.
Originally, aftermarket intakes were supposed to replace those small, restrictive pipes with large, smooth, more free flowing piping.
But people soon realized that, while they were sucking in more air, much more easily, they were pulling in hot air from the engine bay. So the idea of a cold air intake came about. The concept is easy, get it away from the engine heat, and out from behind the hot radiator. For the cars that allowed it, they routed an intake pipe around the radiator. Much like the stock set up is on a 300zx. In other cars, where that wasn't an option, they took the piping and directed it down, to try to get "under" the heat. With proper ducting and shrouding, the hit air from the radiator was being blown above the new intake position. Effectively letting you draw in cooler air.
That is where everything went wrong. The uneducated consumer saw that the intakes down towards the ground made more power, and they wanted it. So for aftermarket companies to make money, they sold what the consumer wanted. The lower they could get the intake, the better people liked it. That is because people didn't realize what was actually happening, but they do know that hot air rises, and therefore, the air down low, must be cooler. And the modern "cold air intake" was born.
So yes, the modern, off the shelf cold air intake is no more effective than any other aftermarket intake. However, even if the aftermarket intake is pulling in hot air from the engine bay, it is still doing it more efficiently than the stock air intake setup was.
The thing to remember is an aftermarket air intake is just freeing up the horsepower that the stock set up was taking away from being restrictive. It can't make the engine produce more power.
That's all an aftermarket intake can do until you start forcing more air into the manifold.
Yeah, I get that a lot. I just take it as a compliment
Old Feb 21, 2012 | 06:33 PM
  #24 (permalink)
flatrex's Avatar
crx hatch sedan
And a good cone filter will have a velocity stack built in which also helps smooth the airflow.
Old Feb 22, 2012 | 11:18 AM
  #25 (permalink)
blackFLgst's Avatar
Probably $#%#ing broke.
LOL @ idiots trying to explain why A CAI in better. Ricer mod, end of story.
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Feb 22, 2012 | 03:15 PM
  #26 (permalink)
Graves's Avatar
I can tell you for my application it is a good mod. A short ram is pretty much just the filter on the MAF tube connected to the TB.
Old Feb 23, 2012 | 07:39 AM
  #27 (permalink)
Niburu's Avatar
Sic semper tyrannis
which will work fine if it's insulated and isolated from the engine bay
if you insulated most stock airfilter boxes and ran a bigger duct with a good fresh air source you'd get the same results
2011 Subaru Forester - the daily driver kid hauler
1990 Miata - track whore
LOVE THIS TAMPA CAR RACING SCENE
Old Feb 23, 2012 | 08:06 AM
  #28 (permalink)
Graves's Avatar
The Focus comes with a "lifetime" air filter system. Fucking PZEV vehicles. This is what the stock system looks like:
No replaceable drop in filter, so a CAI kit gives you that option. Not to mention it is like $400 to replace it all.
I replaced mine with this:
3" tubing, insert for no tuning. I see more MPG and peppier acceleration. With my tune in and the insert removed I may see 10 hp to the wheels. But I can clean my filter and inspect it without dismantling my front end.
Old Feb 23, 2012 | 11:05 AM
  #29 (permalink)
1BADP71's Avatar
E & I Certified
Years ago I swore Bob was crazy ... everybody said I was a hater and an idiot.. now everybody thinks Bob is crazy and I knew I was right all along. It's a good feeling.
You go Bob. Keep up the informative posts !
Old Feb 27, 2012 | 12:31 AM
  #30 (permalink)
Default SomeThings I Agree With
Graves,
One thing I noticed is that most aftermarket intakes have bigger dia pipes. As someone stated,
bigger intakes produce more horsepower than tiny ones. Over time, a computer-designed intake like I see in your lower picture is better than a bigger pipe by itself. Some computer designed intakes have the pipe getting bigger
in the middle and smaller on the ends. By the time the air travels the intake length and gets to the intake valve
it produces more horsepower.
Niburu,
I agree about bigger diameter and putting in a cold air box keeps the filter from pulling in warm engine air.
Flatrex,
You are correct about the velocity stack smoothing the air flow.
Empire,
+1 on a cone shaped filter flowing more than a flat panel style paper filter.
Larger surface area gets air sucked through the filter easier. An engine is an air machine. The easier it breathes,
the more horsepower it produces.
Niburu,
Cold water splashed on an engine whether a high riding SUV or not, will cause condensation
inside a warm distributor and that condensation will sometimes kill the module inside. Sometimes
the condensation will redirect the spark to the wrong terminal.
I suspect that enough water splashed on and/or around electronic parts regardless of the height or
type vehicle will cause electric malfunctions.-Bob
The Focus comes with (edit)....................
