Motor cranks but does not turn over
Old Aug 6, 2010 | 03:01 PM
Amelite's Avatar
Default Motor cranks but does not turn over
I just finished changing my head gaskets and rebuilding the heads. The passenger side valve cover is leaking. I'm starting to think it's warped. I obviously changed the valve cover gaskets out, but we also used gasket sealer. It's still leaking. Would this cause the vehicle to not turn over?
1995 Land Rover Discovery 1
Old Aug 6, 2010 | 03:14 PM
J@meson's Avatar
Resident Ginger Kid...
Timing not correct or an unplugged sensor since you just did all of this work.
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Aug 6, 2010 | 03:27 PM
stealthEG's Avatar
fuel pump turn the key see if u hear the pump dont turn it over
Sum can't handle the single
Old Aug 6, 2010 | 04:52 PM
Amelite's Avatar
It's pumping fuel through the lines, we found out the hard way. We checked the plug wires, and theyre fine. We never messed with the timing on the distributor, when we pulled the heads off, does this mess the timing up? The vehicle has plenty of power, we're jumping it off of a much larger vehicle. What else could it be?
Old Aug 6, 2010 | 09:52 PM
Sneakin Deacon's Avatar
PSSHHH x2
oh jesus... please tell me you set the mechanical timing when you put the heads back on!!!
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Aug 7, 2010 | 08:59 AM
Amelite's Avatar
Fuck me, I did not mess with the timing at all. I had a friend help me who is a diesel mechanic. Am I about fucked? Do I need to pull the heads back off?
Old Aug 7, 2010 | 09:43 AM
GT4SOM's Avatar
Feel teh rally bishes!
So you pulled the heads off but didn't mess with the timing? lol
Seriously though, you gotta set the timing back if you pull off the heads. Is the valve cover siting flush with the gasket?
1992 GTS 3sgte from hell! // 1990 GT liftback Stock 3sgte
Old Aug 7, 2010 | 09:59 AM
Amelite's Avatar
Yes, it's sitting flush, I double checked that. We felt air leaking through, but it was just coming from the exhaust manifold.
In order to set the timing, do I need to pull the heads back off?
Old Aug 7, 2010 | 11:23 AM
J@meson's Avatar
Is it a pushrod motor or overhead cam?
2003 Honda 954RR
Old Aug 7, 2010 | 11:29 AM
Amelite's Avatar
pushrod
