Alignment Shops
Old Jul 18, 2002 | 08:10 AM
ghuey's Avatar
member
Default Alignment Shops
Anyone know a good alignment shop in the clearwater area,Im doing struts and camber on my car this weekend and need someplace close to work to drop it off at once I'm done.....Any help is appreciated.....
~Guy
AE
Old Jul 18, 2002 | 08:25 AM
leadfootedfool's Avatar
Eat soot
You should be able to do it yourself if you want. Place strings around the car and even up the toe, use a plumb bob to do the camber then check everything again. You'd be amazed how well it turns out, much better than any shop for me.
Old Jul 18, 2002 | 09:33 AM
Eat soot
I was figuring he didn't have a camber gauge or slip plates, using that my car is spot on, goons who try to do an alignment (tire places) would make it worse.
Old Jul 18, 2002 | 09:46 AM
Rotary7's Avatar
Get Down-Or-Stay Down
umm ..I cant belive you even gave that kinda advise..
Most shops wont messed with lowered cars cause they go by manufacture specs..When you lower a car..it throws out the camber/caster/toe//some cars have after market camber/caster kits that you can try to get some of your adjustments back..BUt without them it wont be exact...
@leadfootedfool
wut kinda work do you do anyways?
Do you want to be tazed?
Old Jul 18, 2002 | 11:05 AM
Eat soot
i'm a mechanical engineering student at usf
Old Jul 18, 2002 | 11:07 AM
Rotary7's Avatar
Have you ever done mechanical work at a shop?
Why would you tell this guy to brake out strings and do his alignment like that?
They havent used that technic like 15 yrs..lol
Old Jul 18, 2002 | 11:18 AM
Eat soot
Its called grassroots and when your at a race track with nothing else, it gets it close enough and its free.
Old Jul 18, 2002 | 11:19 AM
Eat soot
And you'd be amazed at how many top level scca car use that method.
Old Jul 18, 2002 | 11:23 AM
Rotary7's Avatar
Cuase all they would really need is a little toe adjustment..
If the hit something hard to damage caster/camber then most likely the would not finish the run..
You can only eye so much..Even though manufacture specs has a pretty good range..
Would you try to do this method with smimmed upper control arms like a GM or Ford?
It would be a bitch
