Intake question...
Old Apr 29, 2002 | 02:02 PM
dsonik1's Avatar
Professional Drif-Tater..
first off these specs are from injen for a GSR and a 240 single cam..... and just ta let ya know ( a common mistake) short ram is still cold air and actually gets cooler and cleaner air if your intelligent enough to either add a ram port or (in the case of the 240sx) buy one. so HAHAHAHAHAHAHA yourself. research before retort. oh and by the way with a port or an arm extension(what u call CAI) hte gain on the teg was 18.5 at the wheels. Also you might get a better return if you ditched that K&N supercharger held to your stock intake manifold by silly putty and cardboard.:thumbdown:boink::madfa wk::evil5::evildeal::spoke::fawk : maybe if people used a lil tact when tryin to correct others threads wouldnt get turned into pissing contests.......
Doogie: "Hey did you notice I was tandem with you slidin around that corner?!"
Sonik: " Cool! Did it look hot?, cause if you ever get that close to f'ckin my car up again.... the fuzzy balls hangin from my mirror will be yours
Import Corner Inc.
6432 massachusetts ave
new port richey,fl 34653
1-888-520-9601
GO TO:www.importcornerinc.com
MYSPACE
www.myspace.com/bmwsonik
Old Apr 29, 2002 | 02:09 PM
cobos's Avatar
Yea whatever you say but you still did not adress what i said that could be a 600HP GSR where they tested the short ram before and after.
Not tryin to have a problem with you but that is an impossible gain on a stock gsr.
Old Apr 29, 2002 | 04:10 PM
t3llado's Avatar
injen is dabest !
Old Apr 29, 2002 | 04:11 PM
  #17 (permalink)
t3llado's Avatar
injen is dabest !
Old Apr 29, 2002 | 04:27 PM
  #18 (permalink)
cobos's Avatar
Thank you Robster!
Old Apr 29, 2002 | 05:57 PM
  #19 (permalink)
Fisch's Avatar
Honda makes the best honda parts. They didnt spend million and millions of dollars developing the best streetable cam and simply forget about the intake box. The boxes flow just as well as any intake. Look at Foos car stock airbox. Jackson racing has used stock air boxes on innumerable applications. Even cars with psychotic setups have used simply a stock NSX airbox or a cf duplicate thereof. Dont waste your money and dont belive every thing you read.
