Drilled and Slotted Rotors
Old Jun 3, 2009 | 01:09 PM
  #31 (permalink)
G-Magoo's Avatar
July - Ride of the Month
Originally Posted by omgwtfbbq!
Every reason stated under number 3 points to blank rotors being more effective than a drilled one. Granted Porsche probably has one of the better drilled designs.
Your right, I didnt say that they were more effective, just why and how porsche gets away with cross drilled rotors and have them last.
I love haters..
Originally Posted by VR6exxy
I love your brutal honesty. It makes my day
Build thread
Old Jun 3, 2009 | 01:23 PM
  #32 (permalink)
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Originally Posted by RoadRacer
Hawk HPS pads should be fine. They are a great street pad and a step up for stock.
If you need rotors, get OEM rotors.
They are highly recommended, but putting EBC Greens on the back of my car did more than HPS on the front.
Originally Posted by Chuck 98 RT/10
Understatement of the year. Bars of soap hold up better than EBC pads. A fresh set of EBCs (any color) won't last me a single day on the track.
That said, I do run them on my street Viper because I can get a gazillion miles out of the rotors. But the lack of stopping power is noticable on a heavy car like the Viper. Losing a couple hundred pounds would definitely help.
Greens arent made for Autox or actual racing use. I dont have to wait for mine to heat up to work nicely, which hints that they might not like excessive heat.
Porsche doesnt get excessive either. Their brakes are from Brembo, but didnt go crazy like my Brembo replacements
ASE: Brakes
Old Jun 4, 2009 | 06:17 AM
  #33 (permalink)
Speedz28's Avatar
Domesticated
Your argument is a little flawed. You upgraded pads and rotors at the same time, so you can't really say the rotors helped at all. I'm willing to bet that if you have upgraded to the HPS pads and left OE rotors you would have seen a similar improvement in braking performance, if not the same increase altogether.
My OEM rotors had stress cracks almost all the way around in each front disc, for high speed stop and go the factory rotors just can not dissipate the heat fast enough, and with no slots in the discs serious brake fade from glazing was occurring so I don't believe just pads would have solved those issues. IMO.
Old Jun 4, 2009 | 08:03 AM
  #34 (permalink)
g-50Cab's Avatar
TR Balla Donor Supreme
There is still a problem with the rotors cracking at the drill points - all the turbos, most of the 993's that have drilled rotors have an issue with stress cracks - especially the fronts - especially those that don't have some sort of forced cooling -
EBC? Rotor friendly - but that's about it - chuck have you tried the PFC97's? I'm running porterfield RS now - switched over to pagid's this past weekend (but liked the torque of the porterfield's better) I get a little more glazing on the flat rotors - but like the bite on the slotted better. The slotted do make the pads wear a little bit faster.
yep, got a little bit of lean going here too - suspension next
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
Old Jun 4, 2009 | 09:50 AM
  #35 (permalink)
Chuck 98 RT/10's Avatar
Sexist
I know. And the reds, yellows and blues aren't much better.
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Old Jun 4, 2009 | 09:56 AM
  #36 (permalink)
Sexist
PFC01 on the front for me and they'll put you through the windshield if you're not strapped in. I love 'em. I've heard they have a new and improved pad but I'm so attached to my current setup it would be difficult to move me off it.
I wasted too much money on Pagids R14. Mediocre at best for my application.
Chuck
Old Jun 4, 2009 | 11:16 AM
  #37 (permalink)
omgwtfbbq!'s Avatar
I race sailboats
If you had a light, nimble Honda instead of that redneck mobile dodge "sports car" it wouldn't be a problem chuck
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Jun 4, 2009 | 11:22 AM
  #38 (permalink)
Sexist
LOL Good point. I could disable six cylinders thereby reducing my speed into the corners resulting in a longer pad life. That sounds like fun.
Chuck
Old Jun 4, 2009 | 11:51 AM
  #39 (permalink)
omgwtfbbq!'s Avatar
I race sailboats
Totally man, it would increase your fuel mileage as well, giving you an edge in endurance events. See all these good ideas I have? You should hire me as your race engineer
Old Jun 4, 2009 | 12:06 PM
  #40 (permalink)
schargd's Avatar
I with Chuck on this and he did drive a light nimble Honda around the track. Also, with crossdrilled/slotted rotors and ceramic pads. They are still on the car no cracks after two years.
Try cryogenic processing to decrease potential cracking. For track purposes I would go slotted only because eventually even cryoed rotors will crack it will just take 2-3 times longer. Slotted don't have that problem except powerslots with are a poor design.
For street use I would get OEM rotors some good pads and cryo them. Proven to last 200-300% longer. The Tampa fleet department is testing some SUB ZERO cryo-processed rotors now with great results. They are lasting longer and not near as much brake fade.
