Tubed out Honda.. how fast?
a tube frame chasis is simple its a bunch of tubular metal piping that runs from the front of the car to the back of the car this would be a full tube frame car the sides of the car also has tubular metal piping on the sides and the roof line. Basically instead of a chasis with flat metal where body panels are often welded and/or bolted to there are metal tubes with brackets to hold the body panels on. A roll cage inside a car is not a tube frame. Obituary what you are refering to with wrinkle walls is called a narrow rear end. Narrow rear ends can sometimes (depending on the car and who does the work) end up looking like a tube frame in the back half of the car.
Robster
Robster
You have now seen the entire internet good bye.
Originally posted by "Someone"
Robster
Robster
'98 Eclipse GS-T, Big16G, Greddy FMIC, barely running.
