light weight wheels
Fat tires add drag so that will reduce mph.
Also if the tires are not matched properly you will get too much oversteer or too much understeer. There can be adjustments made to correct or reduce the o/u steer but if there is too much tire then it will make it difficult if not impossible and you will sacrifice performance in other areas.
And obviously if the tires are so fat they rub then you are asking for big trouble.
They also need to be correctly matched to the rim width. Incorrect tire/rim match reduces the sidewall stability.
Car setup is all about compromises.
Of course there positives to fat tires too, but everyone knows what those are.
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Chuck
I would look into upgrading your brakes first if your going to do some track days at sebring. IIRC your brakes are the same as the stock GT mustang? I see those having trouble stopping so much weight,even if you were to get lighter wheels its alot more than the stock GT wheels.
nah a good brake pad and some fluid he will be good. He may not be able to outbrake a lot of ppl, but he wont suffer from brake fade.
I would also recommend SS lines for track duty
And some sort of cooling ducts if possible. Aftermarket pads generate more heat and cooler air will help the life of the brakes.
Eh, on a street vehicle you really don't need air ducts, but removing the heat shields helps alot.
CCW has some nice looking rims. Did see any 17's though?
For what you looking for they have some nice looking rims in the size you need. It would be good to have a really strong rim on a car as heavy as yours.
They're designed to operate at higher heat levels, but they will still easily overheat on a track. Especially with a car that large.
As long as he doesnt hit vtec he should be ok..
CCW FTW!
