What oil you pick?
Old Apr 1, 2008 | 10:21 PM
  #31 (permalink)
Mafiakiller's Avatar
Ballin Beretta
Originally Posted by kaluwa
Castrol GTX is on sale at Advanced for $7.98 a gallon, until April 28th.
+1
Old Apr 1, 2008 | 10:22 PM
  #32 (permalink)
Ballin Beretta
Originally Posted by g-50Cab
Can I use a diesel motor oil in a car?
The newest CJ-4 formulations are now limited in the amounts of Zn and P allowed, compared to the CI-4 formations most users are familiar with. If the oil says CJ-4 or LE or "Low Emissions", even if it also lists CI-4 or CI-4+, more than likely it conforms to the new, lower levels, and should be avoided unless you have a 2007 and later diesel which requires these oils. The verdict is still out in my opinion on the performance of a CJ-4 oil in our application. If you choose to use a diesel or mixed fleet oil, stick to an a CI-4 rated oil. Nowhere should the oil say for emission system protection or for use in engines equipped with particulate emissions filters. Swepco 306 15w40 is one such example of an extraordinary diesel oil we use in our performance engines. Swepco 306 has a healthy dose of boron and moly also for additional ant-wear response.
Worth noting, CI-4 diesel motor oils tend to have more detergents, and it has been determined in the SAE paper "Oil Development for Nascar" that overly detergent motor oils can block or "clean" the anti-wear films off of engine parts, that is one reason that these oils usually have high levels of anti-wear additives. SAE Technical Paper Series 2007-01-3999, Modern Heavy Duty Engine Oils with Lower TBN Showing Excellent Performance, also show that low detergent packages increase the effectiveness of film formation, just as in racing oils tend to have less aggressive detergent packages, which is another reason many be to consider a racing oil versus a diesel oil for your engine. The new ACEA E9 specification will be for a low Zn and P (ash) oil with low TBN, building upon this relationship to ensure that wear protection is not sacrificed for improved detergency or longer drain intervals.
umm i dont think everyone here has a college degree
Old Apr 1, 2008 | 11:31 PM
  #33 (permalink)
shinmei2006's Avatar
^ apparently not everyone has enough sense to use the search button either...
this has been covered numerous times...on this forum...and all across the interwebs
http://www.hashiriya.net
Old Apr 2, 2008 | 09:27 AM
  #34 (permalink)
myltwon's Avatar
Bolt-On 2v GT
Originally Posted by Shinmei2006
SKYLINE SKYLINE SKYLINE, SKYLINE SKYLINE. SKYLINE SKYLINE SKYLINE SKYLINE....SKYLINE.
really shinmei, try to stay on topic...jeez
Old Apr 2, 2008 | 07:17 PM
  #35 (permalink)
Originally Posted by myltwon
LT1 LT1 LT1 LT1, fire fire fire, hot candle wax burns burns burns
wa wuz dat?
Old Apr 2, 2008 | 07:22 PM
  #36 (permalink)
g-50Cab's Avatar
TR Balla Donor Supreme
Then just buy what's ever on sale.....
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
Old Apr 3, 2008 | 05:44 AM
  #37 (permalink)
myltwon's Avatar
Bolt-On 2v GT
whatever's on sale
wa wuz dat?
touche
