Should i go with more sticky 225/50/16 tires or less sticky 245/45/16 ?
Old Apr 5, 2007 | 06:16 AM
aaron1017's Avatar
is not Rotarded anymore!
Lightbulb Should i go with more sticky 225/50/16 tires or less sticky 245/45/16 ?
Exactly what the title says!
* The new car will be putting down ~240-260 rwhp.
* and weigh ~2800 lbs
* The rim size is 16x8.
* I am quite aggressive through turns.
* Loudness isn't a concern.
* Tread wear isnt a big concern, as long as its not 100 or something.
Choices so far:
245/45/16 Yokohama es100
225/50/16 BFGoodrich g-force T/A KD
225/50/16 Kumho MX
Feel free to add more choices if ya want. BE SURE TO INCLUDE THE MAKE, MODEL, and SIZE of the tire you suggest.
I am leaning towards the 245/45/16 es100s at the moment.
LS1/T56 Heads Cam 1994 FD
Zate's Avatar
TR Balla Donor Supreme
I'd go for more contact surface.
Stuff.
Old Apr 5, 2007 | 06:26 AM
aaron1017's Avatar
Too bad you can't see the post times in seconds... cuz that was the fastest reply EVER.
Old Apr 5, 2007 | 06:45 AM
JP Money's Avatar
^is awesome personified
Damn that was fast. lol.
I concur with Zate; wider contact patch is better. However, not all tires on the same size will have the same contact patch. So double check that before you purchase them. Tirerack doesn't have the info on the two 225 sized tires you have listed but I'm sure if you call you can find out. The Yoko's have a 9.4" treadwidth which is the widest I saw of those sized tires. I picked up a set of the Avon Tech M500's in a 245-45-16 for the rear of the S2k. Although it doesn't have quite as large of a treadwidth as the Yoko's, I have had experience with them (the Yoko's) and they (the Yoko's) tend to be a little loud, even when new. So I compared them and the consensus is that they perform just as good, but are more quiet.
Originally Posted by Dwight
Reject a woman, and she will never let it go. One of the many defects of their kind. Also, weak arms.
Old Apr 5, 2007 | 06:48 AM
aaron1017's Avatar
Thanks for the input, finding the contact patch for some tires is difficult. Loudness isnt much of a concern... at all. This car is gonna be the fun/weekend car. My CL will still be my daily driver.
Old Apr 5, 2007 | 06:52 AM
2kSnakeater's Avatar
Pastafarian FOR LIFE!!!!!
what car?
sig under construction
Old Apr 5, 2007 | 06:57 AM
aaron1017's Avatar
Originally Posted by 2kSnakeater
what car?
Secret... for now.
Old Apr 5, 2007 | 07:38 AM
Redglow360's Avatar
What accent?!%?
you might wanna check out the nitto autox tires. They are inbetween the drags and streets for treadwear. I think they are actually a 180 which isnt to bad and should last for a little while.
Everyone Needs Cheerleaders
Old Apr 5, 2007 | 08:02 AM
aaron1017's Avatar
See my original post. What model nitto? What size?
Old Apr 5, 2007 | 08:27 AM
dscivicdx's Avatar
if your going for grip thru the turns and optimum handling go with the wider, low profile tire.
i run the es100's and they are a great low cost tire and they grip really good on a curvy road, but even with my 200whp/190wtq. i have to baby them thru 1st and 2nd or they spin like crazy. they might be a little better in a non-fwd car though.
