Should i go with more sticky 225/50/16 tires or less sticky 245/45/16 ?
Old Apr 5, 2007 | 08:36 AM
JP Money's Avatar
^is awesome personified
Ok, How about the Toyo T1r? From what I've been hearing about these, they are a notch better than the T1s Toyo had b/c the sidewalls are more stiff. That's all I can really think of. Are you going to tell us what kind of car it is? I'm guessing Miata based on what you've posted. Possibly a S2k, too. Both can fit those specs.
Originally Posted by Dwight
Reject a woman, and she will never let it go. One of the many defects of their kind. Also, weak arms.
Old Apr 5, 2007 | 10:17 AM
Jordan Y.'s Avatar
15 seconds EXHILARATION
I know what it is!!1 Well, I sorta have insider info so I won't spoil it by guessing but the rim size narrows it down to only a few cars.
For one, I would always go with the better compound over a wider contact patch. It would be nice to have both but the tire compound, design, sidewall stiffness, etc is #1 250% the most important factor here over another inch or so of rubber on the ground. Basic physics will tell you that the coefficient of friction is more important by orders of magnitude than the contact area to the point that the contact area is unimportant. Basic physics also don't come near to describing tire physics but the same idea applies.
Now, as far as widths go, yes, you can run a 245 on an 8" wheel, but it's toward the small side of the wheel widths recommended for that section width. If you're talking about a fun handling/twisties car, you want to be toward the maximum wheel width for the tire size you're running. It gives the sidewalls better support for less deflection (more stiffness) and makes a better-shaped contact patch with less deformation. A 225 on an 8" wheel is just about right from that perspective, since I believe 8" is the max recommended width for most 225 tires.
I have Hankook Ventus Z212 RS-2s on my 16x8 rims in a 225/50/16 and I have very little sidewall bulge. These tires tend to run wide, more like a 235. When I had Falken Ziex ZE-502s on there there was no bulge at all; they were perfectly straight up and down. I'd recommend the Z212s if you're looking for a less expensive, more autocross oriented tire and don't mind 10-15k mile tire life. You seem to be going more for a touring/open track day tire with a bit more life. I think the Z212s would heat up too much on serious road course stuff but that's just from what I've read. For what I do I love them. Great grip, communicative feel and sound when they're on the edge, cheap price, big meaty tread blocks that don't chunk even at full tread depth. Very conveniently, they have them in both 225/50/16 and 245/45/16, but as I said they run wide. Just remember that when you go wider on the same size rim, you may gain a bit of steady-state grip (constant curve, skidpad stuff) but you lose more steering feel and stability (more "wobbly" through the corners because the tire isn't being supported fully by the rim and can move back and forth more.) Edgeracing has a good price on the Hankooks if you're interested.
Johann (you may not remember him- kid with the White SR20 240) has the ES 100s and he's disappointed with them. They didn't have the kind of grip he was hoping for and while the tire life is good, I believe he said they were getting noisy as they aged. I'll see if he wants to respond to this.
Old Apr 5, 2007 | 10:33 AM
Chuck 98 RT/10's Avatar
Sexist
Kumhos have a rep for some serious grip, but I'm not sure if their grippiest is the model tire you picked out. Dunno. I just run Hoosiers and Michelins.
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Old Apr 5, 2007 | 11:02 AM
aaron1017's Avatar
is not Rotarded anymore!
Teehee, thanks for not telling!
I think I am going with the 245/45/16 es100s for now. I am just ordering two of them to drive home on as the car isn't located in Florida. If I don't like them, I'll make sure they wear out fast or return them with the 30 day free test drive program yokohama has.
Those Hankook Z212 RS-2 look like a good tire. We'll see....
Even though I've decided on the es100s, please continue this thread.
LS1/T56 Heads Cam 1994 FD
Old Apr 5, 2007 | 11:13 AM
RoadRacer's Avatar
Turn 7 at Sebring
what jordan said... Hankook Ventus Rs2 Z212 245-45-16, 93.00 from edgeracing.com
my second choice would be the kumho mx's
Patrick -
Old Apr 5, 2007 | 12:30 PM
g-50Cab's Avatar
TR Balla Donor Supreme
I have about 40 more HP and about the same # and weight - and I have street tires that are the Hankook Rs212 and track tires the Toyo RA1's.
225/45/16 front on 8" and 245/45/16 rears on 9"
Try tires-easy.com - the home of low tire prices for cars, 4x4's and vans
I know quite a few people who have been unhappy with sidewall flexing on the ES100's -
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
Old Apr 6, 2007 | 05:54 AM
  #17 (permalink)
Since I do suspension lowerings and alignments to make a car stick better to the road, I don't understand why a person would prefer less grip.-Bob
Old Apr 6, 2007 | 06:26 AM
  #18 (permalink)
Sexist
Trade off.
More grip = more wear = possibly more expense in the long run and less durable. I'm pretty sure he is talking about a street car.
Besides, which has more grip? It isn't always the widest and it isn't always the compound.
Chuck
Old Apr 6, 2007 | 07:13 AM
  #19 (permalink)
dscivicdx's Avatar
i like the es100's better than any kuhmo i have ever run. they all tended to get a bit slippery when pushed hard. the break away point for the es100's feels a lot higher also. i have no experience with the mx series though. there are a ton of better tires out there, but for a cheap street tire i like the es100's.
Old Apr 6, 2007 | 08:53 AM
  #20 (permalink)
BeQuietAndDrive's Avatar
the whistles go whooo!!!1
Falken Azenis 225/50R16 , 100 bucks a tire from vulcantire.com.
done.
