Headlight Question
Old Apr 1, 2007 | 03:53 PM
Notladstyle's Avatar
King of Ricers
Default Headlight Question
I'm picking up a set of HIDs from Kirk but before I do I have to address a little problem.
One of my lenses has somehow manage to get water in it. A visual inspection(while mounted) yielded no cracks or obvious problems. I've never drilled holes or opened the mount up.
Whats the problem? how do I get rid of the fog and less importantly how do I keep it clear because the last thing I want is 20,000 volt HID bulbs meeting up with some water in there.
notladstyle.blogspot.com
Old Apr 1, 2007 | 04:00 PM
jlude90's Avatar
aspiring luder
break the seal in the back, wipe it out and re-sillicone would be my guess, take it of and see if you can see where its coming in, or take the bulb out, fill it with water and cover the hole, see where it come out and sillicone it there...i'm rambling ideas sorry
Old Apr 1, 2007 | 04:02 PM
King of Ricers
so if I seal the leak the vapor will go away on its own??
Srry, im all about electronics. water vapor and shit like that confuse me...
Old Apr 1, 2007 | 04:05 PM
shinmei2006's Avatar
no no...if you seal it its gonna stay..you gotta clean it out first...remove your headlight, remove the seal, get a heat gun (blow dryer) and dry out the inside, then reseal and youre good to go,
or ask kirk...
http://www.hashiriya.net
Old Apr 1, 2007 | 04:06 PM
jlude90's Avatar
aspiring luder
if you seal it and let it dry completely while its off, then it won't come back
Old Apr 1, 2007 | 04:09 PM
King of Ricers
Aight so I need to open it up, clean and reseal it...
What kind of silicon, and is that what they use at the factory to seal it? im kinda riding the OEM sack
Old Apr 1, 2007 | 04:12 PM
King of Ricers
& side note, what can I do about my misaligned hood? who fixes and how much...
Old Apr 1, 2007 | 04:19 PM
jlude90's Avatar
aspiring luder
i'd say don't crack it open, just take it off, fill it with water and see where it drips out, and then just sillicone that spot, better then re-doing to whole thing and then more then likely having it leak, just go to the hardware store and ask for a waterproof high-temp sealant or some kind of epoxy, just put a dab on the spot its leaking and smear it in with your finger
Old Apr 1, 2007 | 04:24 PM
King of Ricers
high temp sealant - got it.
What if theres no leaks? then im just screwed?
Old Apr 1, 2007 | 04:28 PM
jlude90's Avatar
aspiring luder
then just reseal the whole area where the backing mates to the glass, and then if that doesn't do it, get another gasket to where the bulb goes into the housing, i used a thin sheet of cork on my tails, but think about it, the only place it can get in is where it matesup, it won't leak through solid glass, and it won't leak through solid metal behind it, so there are only 2 places it can really get in you know?
